01-01-2010, 10:55 PM | #1 |
Quarry Creeper Join Date: Nov 2009 Location: Hibbing
| 4 link rods and end links
im building a wreckluse and wondering what is best for making links or what premade ones to use and also what about the tie rod end pieces
01-01-2010, 11:03 PM | #2 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Delrin or aluminum works well..Traxxas Revo rod ends #5347 are about the best thing to use..
01-01-2010, 11:10 PM | #3 |
yeah i heard the revo ends are good ones to go with. as far as aluminum rod would a local hobby shop have it with hole ready to tap?
01-01-2010, 11:47 PM | #4 |
01-02-2010, 09:33 AM | #5 |
I like Jato ends and 8-32 all-thread, with a piece of 1/4" stainless tube. The Jato ends have a longer section for the all-thread to screw into, and the hole size is perfect for 8-32....So are the revo's though....you can tap it, or just screw it in. You can adjust your link lengths, and run the truck before you cut your stainless tube. |
01-02-2010, 10:09 AM | #6 |
Newbie Join Date: Feb 2006 Location: Ottawa Kansas
I agree on the Jato ends. All thread with a slip on cover tube is really the only easy way to do it unless you have a lathe. Solid tapped aluminum is the strongest way to go but I have never seen any thick wall tube that you could just tap and use. Fastball |
01-02-2010, 10:20 AM | #7 |
where would i find some of slip over tube at?
01-02-2010, 12:22 PM | #8 |
Quarry Creeper Join Date: Dec 2008 Location: Ask Your Mom
01-02-2010, 02:29 PM | #9 | |
| Quote: | |
01-02-2010, 02:58 PM | #10 |
Rock Crawler Join Date: Jan 2009 Location: lenoir, nc
JeepinDoug sales link drill bushings that are great for drilling and tapping delrin and aluminum.Link Drill Bushing |
01-02-2010, 10:01 PM | #11 |
why do u guys suggest stainless over aluminum or derlin? just curious
01-03-2010, 07:14 AM | #12 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
01-03-2010, 09:19 AM | #13 |
Rock Crawler Join Date: Feb 2004 Location: Near Pittsburgh, PA
All thread and brake line is the easiest to get a hold of and if it gets messed up, you can make one pretty quickly. BTW..6/32 works well with the std. Traxxas rod ends, sleeve it with 1/4" brake line. |
01-05-2010, 11:48 AM | #14 |
Rock Stacker Join Date: Oct 2009 Location: Canada
I made a set of Delrin link....super easy to work with and slippery on the rocks to boot!! White delin can be dyed to suit your color scheme.
01-12-2010, 12:21 AM | #15 |
Quarry Creeper Join Date: Mar 2009 Location: Peoples Republic of Kalifornia
If you can find entire Traxxas links that work, thats the way to go. I have a WK crawler with a WB of 14" - used T-Maxx links.
01-14-2010, 07:03 AM | #16 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
I used .250 delrin from Fastenal, super easy and slippery!!!!
01-14-2010, 10:25 AM | #17 |
Newbie Join Date: Dec 2009 Location: cali
i use the all thread and brake line for mines as well. simple,easy to make,and available. You can get the all thread from home improvement stores for a little less than $3,and brake line for not that much more.
01-22-2010, 08:02 AM | #18 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
Ok, what size brake line does it take to cover 8-32 all thread... edit nevermind I found it, must have read right over it! duh |
02-22-2010, 12:22 PM | #19 |
Quarry Creeper Join Date: Feb 2005 Location: Atlanta
So what size thread do you all use with your derlin links and can derlin links be bent?
02-23-2010, 11:53 PM | #20 |
RCC Addict Join Date: Jan 2007 Location: San Jose
