01-03-2010, 03:29 PM | #1 |
Rock Crawler Join Date: Nov 2005 Location: Okinawa, Japan
| Suggestions for a Tap and Die set
Well, I am starting to build up my tools for RC work, and I am looking for a good inexpensive tap and die set. What are your suggestions?
01-03-2010, 03:37 PM | #2 |
I just picked this up yesterday. I was stoked when I saw it. They usually don't carry much metric small tools. The one I got looks a bit different. They had two sets. They were just packaged differently. http://www.lowes.com/lowes/lkn?actio...49-1083-358360 opps. didn't see you were out of the US. |
01-04-2010, 01:07 AM | #3 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
You really dont need a set, if your only doing rc stuff even then most sets like hanson have m3 and up to m12, so you figure m3,m4,m5 if that You want HSS for work on stainless , carbon works good on just about everything else, you want taper and bottom if any bottom tapping, dies you want some adjustables which would be HSS anyways, spiral flutes are the bomb, then you need handles and holders. You only want to buy quality items, and they can be had for cheap, osg,emuge,greefield, hanson, all mac tools, snap on and matco use rebadged Hanson |
01-04-2010, 07:58 AM | #4 | |
Quarry Creeper Join Date: Jan 2008 Location: marysville
Home Depot has nothing, I might have to run up to Lowe's | |
01-04-2010, 08:57 AM | #5 |
Rock Stacker Join Date: Nov 2006 Location: Toronto, ON, Canada
I go to a local machine tool shop and buy Dormer tap and dies as I need them and matching drill bits. For taps 2, 2.5, 3, and 4mm is all I use. And I have a 3mm die. Dormer, Portuguese: http://www.dormertools.com/SANDVIK/2...f?OpenDatabase |
01-04-2010, 10:27 AM | #6 | |
01-04-2010, 10:07 PM | #7 |
Rock Stacker Join Date: Feb 2009 Location: Caldwell, Idaho
i bought one a hobby town and it broke doing 3 mm alum.
01-05-2010, 11:47 AM | #8 |
Rock Stacker Join Date: Oct 2009 Location: Canada
Dont cheap out on taps.....buy good ones that will outlast cheapies 10 to 1..... I buy mine from Fastenal!!
01-05-2010, 12:12 PM | #9 |
Newbie Join Date: Oct 2009 Location: Calgary
I agree, you don't need to buy them all. Just buy what you will need. Buying a cheap set will cost you the same as buying just what you need in a good set. I usually like to buy tools that have a replacement warranty. Just in case i break them.
02-25-2010, 04:37 PM | #10 |
Quarry Creeper Join Date: Feb 2005 Location: Atlanta
02-25-2010, 04:47 PM | #11 |
I bought the Tower Hobby set I think it was 19.99 us.
02-25-2010, 05:21 PM | #12 |
Pebble Pounder Join Date: Feb 2005 Location: Chandler, AZ
I've used the great planes metric set. The taps are very fragile. The metric craftsman is better, but doesn't go as small. It's nice to have a whole set around, but once i figured out the size i use most (2mm for me) I bought a quality one from smallparts or fastenal. I can't remember.
02-25-2010, 07:17 PM | #13 | |
Question to the group. Which kind of tap to buy? Taper, plug, or bottoming? Last edited by Bmr4life; 02-25-2010 at 07:20 PM. | |
02-25-2010, 07:27 PM | #14 |
02-25-2010, 07:56 PM | #15 |
Quarry Creeper Join Date: Jun 2007 Location: Sandy,Oregon
I am a firm believer in OSG taps.
02-25-2010, 08:34 PM | #16 | |
Buy yourself some good taps. Like others have said dont get a whole set, figure out what sizes you will need and just buy those. Find a machinist supply place near you and get them there and then if you break one you know where to get one in town so you can get up and running. Also i doubt anybody is going to have a warranty on a tap or die, they break that is life. If you are going to be cutting stainless drill the hole slightly larger than the tap drill chart says otherwise you will be fighting it and breaking taps left and right. Also on stainless you should get a coated tap, it will last much longer assuming you dont break it by pulling sideways on it. Use lube also and break the chip at least every rotation by turning back until you feel a little click...Then keep going. Slow and steady wins the race on this one. | |
02-25-2010, 08:37 PM | #17 |
Grainger sells OSG and Westward HSS taps and my job has an account with them so I'll probably order through them. They even have delrin rod at decent prices so that a plus. So are OSG and Westward equal quality? |
