01-04-2010, 06:26 PM | #1 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
| Standard to metric
I need some standoffs, but they seem to only offer then length I need in standard, so the plan is to buy the standard ones and bore and tap them to metric , m3x.5mm so the ? is what size standard do I need to give me enough meat to bore and tap to metric? 2-56, 4-40, 6-32 ? I dont have standard hardware so I have no idea how it compares to metric. T.I.A |
01-04-2010, 06:42 PM | #2 |
Pebble Pounder Join Date: Dec 2008 Location: Tomball, Tx
2-56 will leave enough meat for you to drill and tap to m3.
01-04-2010, 07:31 PM | #3 |
RCC Addict Join Date: Aug 2009 Location: Earth?
4-40 would be closer. Its just under 3mm. Here the tap and drill sizes. Hope this helps. --Tap---------Drill 2.0mm-------.0619 2-56---------.0669 2.5mm-------.0776 4.40---------.0888 3.0mm-------.0978 6-32---------.1055--(#36) 4.0mm-------.1300 8-32---------.1349--(#29) 10-32--------.1587--(#21) 5.0mm-------.1637 |
01-04-2010, 10:06 PM | #4 |
I think he's talking about drilling out standard threads.....not just opening up an existing hole (correct??). If you run a .098" drill into a tapped 4-40 hole, you will still leave behind threads, where you want strong material to be. McMaster has metric standoffs in hex shape if that helps: http://www.mcmaster.com/#catalog/115/3214/=58jiy8 . |
01-04-2010, 10:46 PM | #5 | ||
| thanks Quote:
01-05-2010, 07:35 AM | #6 |
A 4-40 will have threads out to about .113". An M3 needs to have threads out to about .115", so drilling out a 4-40 would leave you with barely enough material for the screw to grab. I think Rex is right.....a 2-56 standoff would be better.
