01-03-2006, 08:33 PM | #1 |
Rock Crawler Join Date: Jan 2005 Location: Nanakuli
| Drilling solid ....
rods. is there any gig's out there that sets the drill bit in the center of the rod's? because when i have to make cust 1/4" links they sometime come out off a bit. just curious. thanx ka'aina
01-03-2006, 09:38 PM | #2 |
Rock Crawler Join Date: Dec 2004 Location: Land of the Free, because of the Brave
| It won't really hurt if it's off-center a bit. But, you could always put the rod in a vise, on a mill, and use a dial indicator to locate center...major PITA, and definitely not worth the effort. Or, you can drill the rod while it's chucked in a lathe. Use a center drill first, then the drill bit. I usually just use a center punch to mark close to center (eyeball), and then drill in the drill press. -WRM |
01-03-2006, 09:42 PM | #3 |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
If you just have a drill press you can try clamping a piece of steel plate or a piece of wood to the table. Drill a 1/4" hole thru it. Then you can stick the link up thru the hole to start a center point with a drill. Jay |
01-04-2006, 11:31 AM | #4 | |
but thanx for all the info. ka'aina | |
01-05-2006, 05:28 PM | #5 |
RCC Addict Join Date: Aug 2005 Location: Akron
This same thing has been bugging me. I'm finally to the part where I need to drill and tap the rods. I think i'm going going to give my drill press adapter for a corded drill a shot.
01-05-2006, 06:27 PM | #6 |
Rock Crawler Join Date: Apr 2004 Location: Longmont, CO
Rok's idea of drilling a 1/4" hole and then inserting the rod is a real good one. These can help alot too: |
01-14-2006, 03:18 AM | #7 |
Newbie Join Date: Oct 2005 Location: Aiea
what I use to find the center of the rod is a 1/4 inch drill bit.I line the bit up to the rod so that they are parallel to each other then use the bit as a punch.if you want staright holes the you use 2 drills (or a keyed chuck) each going opposite ways. Beware I have broken lots of bits.
