01-16-2010, 12:25 AM | #1 |
RCC Addict Join Date: Jan 2007 Location: San Jose
| 5150's Plastic Bender.......
I am going to try to make a plastic bender using a toaster as the basic platform. Tools used to disassemble toaster: -Good solid metal snipers. -flat head screw driver. -plyers -star key (I used snips and muscle). Pictures to come. Last edited by 5150bronco; 01-16-2010 at 02:29 AM. |
01-16-2010, 02:39 AM | #2 |
Quarry Creeper Join Date: Aug 2008 Location: Citrus Heights
You are literally playing with fire. A real bending strip is not that expensive, under $50. And they are designed to do this type of work. You are going to have a shock and burn hazard on your hands. My advice is don't cobble it. |
01-16-2010, 02:55 AM | #3 |
RCC Addict Join Date: Jul 2008 Location: Sin City
Ya but an old toaster is next to nothing. Im interested to see it. |
01-16-2010, 01:53 PM | #4 |
| okay. well, i do respect your opinion, seems you know whats up from other forum, but could you explain? I am going to take pics and show you what I have. I dont see any issues due to what I have done, but please comment. thanks kill.
01-16-2010, 02:27 PM | #5 |
this is what I kept after taking apart toaster. rod is above here on left side, which is left of the orange thing, which that is what turns on the heat. So, I used got it to work and the four heating elements got hot, but the two center got really red hot. there was one small spark in the center one so I am not sure why or how safe this is as it is set up. does not seem to be able to control the heat even though the rod that you use to toast the bread does not control heat like i thought. I am going to try again, but maybe just keeping the heating elements than figuring out a way to control heat, volt regulator or something. what is that something? comments and suggestions welcome. thanks. |
01-18-2010, 12:40 AM | #6 |
any suggestions for something to control volts or power if I was to just use the heating elements?
01-20-2010, 03:10 PM | #7 |
Rock Crawler Join Date: Dec 2009 Location: Beaumont, Tx
Measure you output to the elements. ac or dc? volts? Then I can help
01-20-2010, 03:12 PM | #8 |
A toaster's light and dark settings come from a timer/heat sensor. The elements are just on.
01-20-2010, 06:34 PM | #9 | |
I would guess ac since it plugs into wall, right. volts...., I can test with multimeter......, right? plug in wall than not sure how to test? THANKS A LOT! | |
01-20-2010, 07:14 PM | #10 | |
No offense, but I see this ending badly......please go back and re-read killbucket's post. $50 can save you a lot of grief. . | |
01-21-2010, 02:51 AM | #11 |
do you have any suggestions chud?
01-21-2010, 04:12 AM | #12 |
| I feel like I'm watching a suicide in progress. You are playing with live AC, and it can kill you.Throw all that away, and finish your life as planned. Get one of these, it's what I have: http://www.briskheat.com/p-152-rh-pl...ip-heater.aspx JUST $37! EDIT: Unless you go to TAP, where you will pay $70. No joke. http://www.tapplastics.com/shop/product.php?pid=169 Last edited by killbucket; 01-22-2010 at 12:28 PM. |
01-21-2010, 07:48 AM | #13 | |
I don't see a transformer so I would have to assume that the elements are AC. Yes multimeter set to AC and measure the elements. Its not going to be free to try to control it. I would cut the elements off AND cap the wires and just use the cooler ones. Or if you need three, cut out the bad one and wire up the other good one in series with the cool elements. 110 volts don't hurt for long | |
01-21-2010, 08:19 AM | #14 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Push the lever down and the wires get hot, YEAH TOAST! http://www.youtube.com/watch?v=LoFhNepDTuE Last edited by hitman46mod; 01-21-2010 at 08:23 AM. |
01-21-2010, 09:00 AM | #15 | |
Killbucket's solution looks much safer, and it's only $37. I know part of the fun in projects like this is the do-it-yourself satisfaction, but some things aren't worth geting hurt for. | |
01-21-2010, 09:13 AM | #16 |
Hurt? No, your setup can KILL you. |
01-21-2010, 06:51 PM | #17 |
| oh......, okay. I get that.......! Dam, I wanted to try and make something. so I guess i will toss the stuff. :( thanks for letting me know. glad i did this thread to find out. No offense takin chud. thanks for you input, that is why i put this out there. |
01-22-2010, 01:59 AM | #18 | |
I will look into that and considering I dont have as much experience or knowledge, I appreciate the feedback kill. | |
01-22-2010, 02:19 AM | #19 | |
01-22-2010, 03:26 AM | #20 |
Yes. Delrin is also a thermoplastic, so yes. About 1/4' inch. Anything thicker needs industrial equipment. |
