01-31-2010, 02:44 AM | #1 |
RCC Addict Join Date: May 2006 Location: nor-cal
| removing powder coat
what are my options to removing powder coat from aluminum chassis plates?
01-31-2010, 06:24 AM | #2 |
Rock Crawler Join Date: Sep 2009 Location: The BYB Compound
a little oven cleaner works great
01-31-2010, 07:09 AM | #3 |
Quarry Creeper Join Date: Feb 2008 Location: Bay City
Ya have 2 choices that are easy. Air craft stripper (messy) of burn it off with a torch then sand blast it . I deal with a powder coater every day. and this is how they strip screwed up parts. I dont even bother painting stuff any more, I just have it coated.
01-31-2010, 07:15 AM | #4 |
Rock Crawler Join Date: Jan 2007 Location: monson
this is what I have used with good success. |
01-31-2010, 07:26 AM | #5 |
thanks for the help |
01-31-2010, 11:07 AM | #6 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
I also deal with powder almost every day, air craft remover is my cleaner of choice for bad coatings.
01-31-2010, 05:54 PM | #7 |
where can I get some air craft cleaner?
01-31-2010, 07:06 PM | #8 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Spray on Gunk Gasket remover. It will literally blow the PC off. |
01-31-2010, 07:22 PM | #9 |
01-31-2010, 07:34 PM | #10 |
thanks guys, I will pick some up when I go to autozone, to pick up parts for the 1:1's later in the week |
02-01-2010, 05:53 AM | #11 |
02-01-2010, 06:58 AM | #12 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
If you believe in "Truth in Advertising" then it should....only one way to find out, then let us know!!
02-01-2010, 08:50 AM | #13 | |
| Quote: | |
02-09-2010, 09:33 PM | #14 |
Newbie Join Date: Dec 2009 Location: Satellite Beach
Blast It
02-09-2010, 10:50 PM | #15 |
RCC Addict Join Date: Mar 2008 Location: SSF
Do not use heat. Heat will anneal the aluminum making it really soft. Unless you can figure out how to temper it at home. |
02-10-2010, 08:16 AM | #16 |
| I know to much heat is bad for any metal, I work in the metal fab industry! and blasting it isnt an option at this point as mine is to big:?
02-10-2010, 09:48 AM | #17 |
Quarry Creeper Join Date: Aug 2008 Location: Northern, Mi
I use to blast well drilling trucks and L.P. tanks that where all PC. We used a rather large blaster. I found that if you run the blaster over a larger area and heat the metal the PC would blow right off. But im Clayton78, Aircraft stipper works very nice also. Some times you might have to redo some spots that don't want to come off. Dont get it on your hands |
