02-05-2010, 07:51 AM | #1 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
| Dyeing Delrin
Well I posted some basic instructions on this subject awhile ago but thought I would do a little more detailed post with pictures. This technique works extremely well for me and I hope this helps those who want to dye delrin. You will need a few thing to start, first a package of Rit dye in the color of your choosing. Here is my setup. For a heat source I use an MSR backpacking stove. A small stainless bowl with enough water to cover the strainer by an inch or so. To hold the parts away from the bottom of the pot, I used a small strainer from Walmart with a makshift hanger made from bicycle spokes. This suspends my parts approx 3/4" from the bottom of the pot. Next you need to have a pail of cold water to set the color later on. Next, bring the water to a boil and pour dye in while stirring. place parts in the small strainer and place into boiling water/dye mix Let it sit and give the strainer a small shake every once in awhile checking every 5 minutes or so When your happy with the progress/color remove strainer from boiling pot and dunk in the pail to set color. I didnt get a pic of the dunk because I did it fast and am not that coordinated!! After the cold water dunk, dry your parts off and your done!! I hope I covered everything, just be sure you use this in a well vented area and I also keep a fire extinguiser handy because of the stove I use. Enjoy!!! Last edited by Captaincrash; 02-05-2010 at 08:03 AM. |
02-05-2010, 08:08 AM | #2 |
I forgot to mention, this session took approx 20 minutes to complete. Also the larger parts ended up with a cool brownish orange streaking through it that I likely could have gotten rid of by leaving in longer but I liked it so I stopped. I did large parts in the past and left them for 1/2 hour or more to get them jet black. |
02-05-2010, 10:35 AM | #3 |
Quarry Creeper Join Date: Jul 2008 Location: Ventura, Ca
any idea on how deep the dye penetrates? I wanted to dye some blanks, than machine some rims out of them to give me a multi color wheel. thinking black and white or red and white.
02-05-2010, 11:03 AM | #4 |
Not very deep at all maybe 1mm......I will get a pic for you tomorrow of a piece I cut to check depth.
