02-06-2010, 08:32 PM | #1 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
| Delrin link questions
I was looking to make my own delrin links, i was going to use some 1/4" delrin tube that has 1/8" inside diameter (same size as the aluminum links i have). And i was just going to use set screws in the rod ends, will this hold up? Or will it be "weak" because its hollow? Not really fimilair with delrin links, so sorry if this is a dumb question...
02-06-2010, 09:47 PM | #2 |
RCC Addict Join Date: Aug 2009 Location: Earth?
1/4 inch will have a LOT of flex, and the longer you make the links the worse the flex will be. I use 5/16 on my Losi. Thet are only 83mm and work great at that length.
02-06-2010, 11:27 PM | #3 |
You can use delrin tube if you use allthread all the way through. It'll make it strong enough to live happily. |
02-07-2010, 07:00 AM | #4 |
WNYRCRC Join Date: Nov 2008 Location: Western New York
I use 1/4" for my 1.9 links. 5/16" rod for my 2.2. I have 3/8 also when I need longer links. I get the rod from McMaster Carr. Its solid delrin rod. I drill the 5/16 with 4 mm and the 1/4 with 3 mm. Never have had any issues.
02-07-2010, 08:10 AM | #5 | |
Thats where i was going to buy it as well, thanks for the input, ill look into 5/16" tube. | |
02-07-2010, 08:29 AM | #6 |
Couldnt find 5/16" delrin rod on mcmaster, only 1/4", 1/2", 5/8" ect...
02-07-2010, 09:01 AM | #7 |
I've used the 1/4" tube for steering links, upper links, and chassis spreaders. I use 5/16" rod for lower links, it's as small as I'd want to go for those. McMaster is where I got the 5/16" rod. |
02-07-2010, 09:09 AM | #8 | |
And you just used set screws in the 5/16" rod? I guess ill get some of that and see how well i can drill it out. | |
02-07-2010, 10:57 AM | #10 | |
I used JeepinDoug's drill guides to drill the holes, check out the tool vendor's section. They work well, not too expensive. | |
02-07-2010, 11:50 AM | #11 |
| Wow! Those are cool! Thanks for showing me them, this should be a lot easier now. |
02-07-2010, 12:01 PM | #12 |
Quarry Creeper Join Date: Jul 2008 Location: Splendora
Yeah the link bushings are nice I have all 3 of them and have built many links in different sizes for myself and some of my buddies.
