02-14-2010, 08:11 PM | #1 |
RCC Addict Join Date: Dec 2009 Location: Rock Bouncin' with the Patented Technique
| Diffaculty of building a chassis based off a 1:1
Just how hard is it to build a tube chassis based off a 1:1?
02-15-2010, 03:12 PM | #2 |
Rock Stacker Join Date: Dec 2009 Location: Clemson
You can make an RC replica as accurate as you want, and it isn't incredibly hard. The things to consider: - Budget - Off the shelf parts available - what can you borrow from other trucks? - Custom fabrication required - what do you have to make? - Design work required - how do you put together the parts you have and make the scale look convincing? I'd make a first build as simple as possible. A track bar looks cool as heck and simple to do, until you build it and realize the stupid thing just won't flex if it isn't done right. I've found many similar cases in my first replica build, and you will end up burnt out long before the truck rolls. Make sure you pick a 1:1 that is adaptable to standard transmissions, axles, steering, and batteries. Once there, you can use the truck as a platform to try more exotic ideas and work into better replicas. Expect problems with your first build, there will be plenty more opportunities to improve. The actual tube work is extremely easy once you get used to it. Jigs make a big difference if you find a way to build them. Hrm.. I hope I haven't missed the actual question here.. Last edited by vw_thing; 02-15-2010 at 03:18 PM. |
02-15-2010, 03:40 PM | #3 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
You can get it close, but there are a few factors that you'll need to work around. Steering Servo - is far bigger than a steering box on a crawler and can be a challenge to incorporate into the design. Shocks - are often larger than scale, so will also need to be worked around. |
02-15-2010, 06:11 PM | #4 |
This is the buggy I plan on building. Its Adam Woodlee's creation from Wide Open Design. Its there King of the Hammers buggy. I gotta get permission from the owner to build it! Last edited by country_crawler; 02-15-2010 at 06:14 PM. |
02-15-2010, 06:42 PM | #5 |
Looks like a good design to start from. 4 link is not hard, there are plenty of set formulas to follow there. The overhangs on that frame will make battery mounting pretty simple, and they give enough clearance for axle-mounted servos. The flowing curves can be tricky, but you really just have to take your time All you would need for that one is some pictures without the skins. . Go for it, and post some pictures. |
02-15-2010, 09:10 PM | #6 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
you dont need permission to make a replica r/c truck of that... IF anything they should be honored...
02-16-2010, 06:25 AM | #7 |
02-16-2010, 08:10 AM | #8 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
If anything, I would ask them for more detailed pictures of the rig. Some build up shots, shots with the body off, etc. The more the better, these are good for getting general dimensions and scale. When building a replica, all you really need to shoot for is getting the major look and feel of the rig- don't stress out about the shocks and steering servo. Also, make sure in the end, you have a usable rig- I cannot tell you how many scale builds I have done that looked awesome and replicated the 1:1 very well, but performed like a turd... crushed and rebuild. Don't burn your house down. p!nK | |
02-16-2010, 08:17 AM | #9 | |
02-16-2010, 08:41 AM | #10 | |
You often have to sacrifice a bit of scale look in order to mount larger than scale items. Don't stress about keeping an exact scale. | |
02-16-2010, 12:03 PM | #11 |
it is easier to build a chassis around a servo than to build a servo around a chassis. p!nK |
02-16-2010, 05:29 PM | #12 | |
02-17-2010, 01:11 AM | #13 | |
Quarry Creeper Join Date: Jul 2007 Location: Holland,OH
The guy probably won't say no... and it's great if they say yes. PG got me all the info and requested pics of his rig. One of these days I'll be able to get'r done. Good luck with your build | |
