02-20-2010, 06:09 PM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
| Which brakeline, coated or not ?
Which is the best to use, coated or non-coated brake line? Pros and cons of each ? Thanks Joe |
02-20-2010, 06:16 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
As far as I know galvanised coating when heated makes very poisonous fumes, Sadly all thats all I can get so I have to remove the coating before I braze.
02-20-2010, 08:57 PM | #3 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
Non coated but I'd still sand it off before you braze it.
02-20-2010, 10:18 PM | #4 |
Quarry Creeper Join Date: Jul 2006 Location: Huntspatch
I've used both the galvinized and the coated (the coated type I bought is kinda OD green). I found it alot easier to use the coated because its easier to clean before you braze, plus you dont have to worry about the fumes-(can be overcome by a fan) Both came out good, but alot of prep was put into both beforehand. I'd go for the coated myself-easier prep. than galvinized. Just my 2 cents. Good Flux & Good luck
02-21-2010, 12:06 PM | #5 |
thanks guys, I was not wanting to do the galvinized, I remember the bad fumes from years ago when I was a welders helper.
02-21-2010, 02:22 PM | #6 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
You could use 1/8" or 3/16" solid rod instead... No worries about galvaniized coatings there..
02-21-2010, 03:08 PM | #7 |
how is 3/16 rod for brazing compared to brake line? seems it would be a little harder to do and I am a "wookie" at brazing |
02-21-2010, 07:47 PM | #8 | |
Rock Stacker Join Date: Dec 2009 Location: Clemson
I think the new OD green coating is PVF (plastic). It needs to be stripped completely before brazing or welding. The burning plastic smells pretty bad and could be toxic. Zinc galvanize can make you feel sick for a few days, but causes no permanent damage. Just keep your head out of the path of the fumes and give the fumes a place to go. Either coating you get, zinc or PVF, will hurt the bond between the braze and steel to some extent. You want the joint as clean as possible. Zinc is a little more forgiving here, as it is still a metal (certain fillers are made for welding zinc-coated steel). | |
02-22-2010, 01:42 AM | #9 |
RCC Addict Join Date: Jan 2007 Location: San Jose
3/16th steel brakeline looks more scale. sanding it does not take more than couple seconds.
