02-22-2010, 11:34 PM | #1 |
| need to learn to cut a comm.
will a basic mini lathe like the 7"x12" work on motor comms? or do I need smaller? I want to do my 500 and 380 and micro motors. any special tool needed to hold the comm in the chuck? |
02-23-2010, 05:41 PM | #2 |
A specialized comm lathe is the ultimate solution, as it holds the arm exactly like it is in the motor. I've tried cutting comms with a regular lathe about 20 years ago. First tried putting it in a 3 jaw chuck gripping the stacks. Didn't work worth a flip. The stacks aren't perfectly concentric with the comm, so the cut actually made it worse. Tinkered around with some other techniques, but nothing turned out like a cut on a real comm lathe. If you have a good collet, and a way to hold the other end of the shaft, it might work, but I'm not sure. |
02-25-2010, 12:57 AM | #3 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
most 7x's as they are commonly referred to are ok for non precise work out of the box, but runout will be pretty bad, I have a grizzly 7x 12 that has some important mods to it, tapered headstock bearings - is a must adjustable backing plate for 3 jaw chuck- I can get runout under .0005 with a 3 jaw chuck ,dont need to use a 4 jaw to get these kind of low runout numbers |
02-25-2010, 10:00 AM | #4 |
Rock Stacker Join Date: Oct 2009 Location: Arlington
Not to say that I dont believe you... meehidont believe you can get runout to half a thousandth. Heh how do you accomplish this? A standard 3 jaw is hard to get a part within 5 thousanths on a microlathe.
02-25-2010, 10:33 AM | #5 | |
http://warhammer.mcc.virginia.edu/ty...tTruBackplate/ I had this guy build me one, one of the best upgrades and a must if you want to use a 3 jaw and get decent results Last edited by Joat; 02-25-2010 at 10:43 AM. | |
03-03-2010, 09:51 PM | #6 |
so a 4 jaw is better if your looking to get a lathe? how about the combo lathe/mills? to cluttered? I was thinking it would probably be better to have a seperate mill since I have the room. |
03-15-2010, 12:41 AM | #7 |
| Sorry did not see your post, if you have a nono adjustable backing plate then yes a 4 jaw,if you have a adjustable backing plate then 3 jaw, I have a 4 jaw and it's still in the box, also a 4 jaw is good for non round shaped items.
