02-26-2010, 07:53 AM | #1 |
Quarry Creeper Join Date: Feb 2005 Location: Atlanta
| Quick size question for threaded rod tubing.
What size ID do I need to cover 6/32 thread rod. Now what about 8/32" thread rod? I've seen 1/4" mentioned, but is that ID? And is that for 6/32" or 8/32'? Thank you |
02-26-2010, 05:16 PM | #2 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
02-26-2010, 06:18 PM | #3 |
02-28-2010, 01:51 PM | #4 |
Alright, I have some 3/16" brake line with flared ends. The 6/32" doesn't fit. Is that due to the flarred end. Only reason I haven't cut it off yet is then I can't return it if that's not the reason. Thanks. |
02-28-2010, 05:08 PM | #5 |
Rock Stacker Join Date: Dec 2009 Location: Clemson
Brakeline is measured in outer diameter. "3/16in" brakeline is 3/16in O.D., ~1/8in I.D.. It can be tapped for 6-32 (loose fit), but will not sleeve it. You need 1/4in brakeline (3/16in I.D.) to sleeve the 6-32 rod. It is a bit of a loose fit, but the rod ends will hold it in place just fine. |
02-28-2010, 05:12 PM | #6 | |
So what size do I need for 8/32", is there a 5/16" OD brake line? | |
02-28-2010, 06:09 PM | #7 |
Pebble Pounder Join Date: Feb 2010 Location: West Orange
I use al. solid rod and tap the ends with a 4-40 tap. strong and easy to do.
03-04-2010, 12:05 AM | #8 |
no talent hack Join Date: Feb 2007 Location: Redwood City
1/4" brake line should work for 8-32
03-10-2010, 06:59 AM | #9 |
03-10-2010, 12:03 PM | #10 |
