02-27-2010, 02:46 PM | #1 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
| Air sheet metal shears??
Was wanting a small brake and shear but came across a air sheet metal shear, will it make a good straight cut or will it curl up the metal too bad? or would a nibbler be better? Thanks Joe |
02-27-2010, 02:58 PM | #2 |
DOOH!!! Join Date: Feb 2007 Location: AZ
You can get a straighter cut from the air shears but they will curl the edge a bit, the nibbler produces a better edge but a bit tougher to hold a straight edge. If it was me, i'd go for the nibbler. There could be a lot of times you could clamp a straight edge to your work to run against. Plus I think it would be better for light work, smaller stuff.. |
02-27-2010, 04:30 PM | #3 |
cool, thanks. I was mainly going to use it for plates for a winch to sat on for the bumper I'm going to make and for plates for the rock guards too! Here nibbler, nibbler....... |
