03-03-2010, 09:57 AM | #1 |
Rock Stacker Join Date: Nov 2009 Location: santa cruz
| cutting delrin
whats the best way to cut delrin, square, and equal length
03-03-2010, 06:18 PM | #2 |
Quarry Creeper Join Date: Nov 2006 Location: Manchester
A table saw works great for me.
03-03-2010, 06:30 PM | #3 |
I joined the Band! Join Date: Jan 2010 Location: Lanc.
03-03-2010, 06:51 PM | #4 |
RCC Addict Join Date: Aug 2009 Location: Earth?
I use a radial arm saw. I use a clamp on the guard as a stop. Slide the delrin rod untill it hits the clamp, push a scrap piece of wood next to the delrin ( to keep the cutting blade from flexing the delrin ), and cut. Every one comes out the same length. Make a few test cuts on wood first untill you get the length correct.
03-03-2010, 06:58 PM | #5 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
I use a band saw with a 18tpi blade or my scroll saw with a clamp/guard and a 18tpi blade.
03-03-2010, 07:13 PM | #6 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
12" miter saw................bob .... |
03-03-2010, 09:00 PM | #7 |
Rock Stacker Join Date: Jun 2009 Location: south western pa
03-03-2010, 09:32 PM | #8 |
Pebble Pounder Join Date: Dec 2009 Location: scotts valley
Band saw. Safe, quick and easy.
03-03-2010, 10:38 PM | #9 |
Pebble Pounder Join Date: Aug 2009 Location: Glenwood Springs
band saw. safe quick and easy x 2.
03-10-2010, 06:56 AM | #10 |
band saw with a wood cutting blade (not sure on the teeth count) cuts very clean
03-10-2010, 05:29 PM | #11 |
Pebble Pounder Join Date: Oct 2009 Location: canada
Table saw is the best
03-10-2010, 06:06 PM | #12 |
| I cut a lot of Delrin, and when machining, it has to be square so it holds securely in the vise. I use my table saw to rip it into lengths, and a cross-cut sled on the table saw to cut it into blocks. I plan to pick up a chop saw soon though to cut it into blocks instead of the cross-cut sled. I used to use a band saw, but I would have to machine the edges to make sure they held securely in the vise (Delrin is a slippery little bugger!)......the band saw just didn't leave a consistent enough cut like the table saw does. . |
03-11-2010, 01:56 AM | #13 |
03-14-2010, 02:53 PM | #14 |
Newbie Join Date: Feb 2010 Location: Chicago
Miter box and 12" saw like the one pictured above works great. Just line up your links, make a notch, and then cut them individually. They are cheap too, $10-15 for miter box and saw combo from a hardware store.
