03-11-2010, 01:05 AM | #1 |
Rock Crawler Join Date: Jun 2009 Location: SF
| Servo tape that won't quit?
What is the meanest, baddest, toughest, low down servo tape in all the town? Sho nuff! Anyone gets the movie reference gets a high five! But really, what is the tough servo tape that won't give up on me? |
03-11-2010, 01:11 AM | #2 |
Like a boss... Join Date: Feb 2008 Location: NorCal
MIP servo tape. IMHO...hands down the best and still comes off clean. |
03-11-2010, 01:45 AM | #3 |
Thanks mike! You have it in stock?
03-11-2010, 05:23 AM | #4 |
Rock Crawler Join Date: Nov 2009 Location: Wildwood
Wasnt the name of the movie sho nuff?, or did they just say that a bunch? I use 3m double sided foam tape with great success.
03-11-2010, 05:42 AM | #5 |
Quarry Creeper Join Date: May 2005 Location: Auburn
That clear gunk in the red roll. (google says Parma) The old black stuff just isnt what it used to be. Shoegoo or Marine goop works better. Only way to stick power switches to something. |
03-11-2010, 05:49 AM | #6 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
automotive trim attachment tape,,,paint and body repair stores carry it,,or check with your local body shop
03-11-2010, 06:01 AM | #7 | |
Rock Crawler Join Date: Dec 2005 Location: Huntertown, In
Now I need to find something that works as good to attach teflon to my Bully axles. | |
03-11-2010, 07:19 AM | #8 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
My apologies in advance for jacking the thread a bit. I've been using the "cutting with thread" method lately to remove taped down electronics, with great success. No more screwdriver gouges on the chassis or on the bottom of the electronics cases. Narly1 |
03-11-2010, 08:33 AM | #9 | |
Newbie Join Date: Feb 2010 Location: Ronkonkoma
I have been using this in my oval cars. To keep everything in its place one of the "oldtimer" told me to double up on the tape. With some of the hits taken at high speed, everything has stayed in place. | |
03-11-2010, 08:43 AM | #10 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
The 3M double sided heavy duty tape works the best!
03-11-2010, 09:39 AM | #11 |
Rock Stacker Join Date: Oct 2009 Location: Arlington
This stuff is way cooler than regular old tape or velcro: http://www.andybaird.com/travels/gertie/superlock.htm |
03-11-2010, 10:35 PM | #12 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
The Parma 3M silicone tape mentioned above is killer, and I've also used BRP Super Sticky servo tape...nice and thin and holds insanely well. http://www3.towerhobbies.com/cgi-bin...&I=LXPM77&P=ML |
03-11-2010, 11:05 PM | #13 |
Ive had nothing but bad luck with that clear "parma)" stuff. And no, the movie is not called "Sho Nuff" . Here's a hint the bad guy was called The Shogun Of Harlem and the musical guest was El DeBarge.
03-12-2010, 10:22 AM | #14 |
Rock Stacker Join Date: Mar 2010 Location: San Antonio
Movie sounds like The Last Dragon.... Bruce Le-Roy...lol Tape I would recommend is 3M VHB. Will hold anything, but it can be a little difficult to get off... |
03-12-2010, 10:49 AM | #15 |
Rock Crawler Join Date: Feb 2008 Location: Anniston, Alabama
Yup, It is Last Dragon. SHO-NUFF!!!! |
03-12-2010, 12:24 PM | #16 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
I just use carpet tape.
03-12-2010, 12:29 PM | #17 |
Pickle I have the MIP MXT-1 tape in stock. I agree with you I hate the Parma clear stuff. It's okay if your going to do a large section like a big esc or rx. but you have to be very careful in how you handle it. You almost cannot touch it at all. The only upside to the parma stuff is it comes off clean. The MIP tape gives you best of both worlds IMO. The only downside I can tell you is cost. They don't give you much. Like two 8 inch strips. Mike |
03-12-2010, 01:09 PM | #18 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
I took Mike's advice and tried the MIP tape yesterday, works great |
03-12-2010, 01:15 PM | #19 |
Rock Crawler Join Date: Apr 2009 Location: Somewhere deep within the barn doors
I use the clear parma servo tape as well... Works great Its important to keep a few things in mind though when using servo tape... The best servo tape in the world will fail if it is not well stored or not applied to a completely and correctly cleaned surface. Make sure to thoroughly clean the surface with rubbing alchol and also make sure when purchasing you are buying a fully sealed blister pack. If not properly sealed/stored the adhesive will deteriorat and the tape will fai... Hope that helps Heath |
03-12-2010, 02:28 PM | #20 |
Small dab of shoe goo
