03-18-2010, 06:13 PM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Reno
| Delrin thickness ?
I want to make my own body less chassis for my moa losi out of delrin. I was wondering what thickness to use to get proper strength. I was thinking of using 3/16", but thought i'd ask before i order. Also, is 1/4" think enough for lower links, or should i go bigger? Thanks |
03-18-2010, 09:58 PM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: ewetah
most chassis' are 1/8" delrin and for lower links are you talking about solid rod or sheet delrin? For round rod delrin I use 3/8", some people use 5/16"; if you're using flat sheet delrin I don't know but would think 1/4" is a little thin.
03-18-2010, 10:48 PM | #3 |
it will be solid delrin rod for the links.
03-19-2010, 05:42 AM | #4 |
I have used 1/8" and it works just fine.
03-20-2010, 12:10 PM | #5 |
Newbie Join Date: Feb 2010 Location: Chicago
07-29-2011, 10:40 PM | #6 |
Newbie Join Date: Jul 2011 Location: SoCal
| A bit difficult to find
I had been looking for the thin delrin sheet listed here, and was having no luck. After searching and thinking I found it, most places say they carry it, I would call, and they would say 'it is on back order' or some other lame excuse. I finally found Industrial Plastic, and they had it in both Black and White. And they had it in big sheets - like plywood size. You need to call, it is only on their site as small pieces. Yeah. Thought you would want to know. |
08-02-2011, 01:53 PM | #7 |
i used 1/8 for my chassis and its been running strong for a year. as for the links my BULLY has 5/16 and my SCX10 has 1/4. try McMASTER CARR for the sheets and rods , nice variety to choose from Last edited by crawlhog; 08-02-2011 at 01:58 PM. |
08-02-2011, 01:57 PM | #8 |
I wouldn't use 1/4" for your links. I use 5/16" on my 1.9 SCX scaler and have bent them under a few times from the torque of the tires. A 2.2 Comp with front and rear dig is asking for trouble with anything less than 5/16...in fact I'd go bigger.
08-02-2011, 02:46 PM | #9 |
Pebble Pounder Join Date: Dec 2010 Location: Elk Grove
I just made a bodyless upper chassis for my GC3A last night. Made it out of a $2 cuttingboard from Walmart. Used a cutoff wheel to get a general shape to it, then tried to get the details with an air sander. A few pictures: Hoped to look like: Outcome: Thickness: Hope this helps! |
08-02-2011, 03:20 PM | #10 |
For a 2.2, I would use 1/8th" for the upper and 5/16th"+ for links. I use 1/8th" Lexan (the brand name, not just "clear polycarbonite sheet") for uppers. For both Lexan & Delrin, keep the outer edge to cutout/window dimension 1/4"+. Also try to get "posts" from outer edge to screw mounting lined up so you have better force transfer when you're upside down. |
08-02-2011, 05:57 PM | #11 |
Quarry Creeper Join Date: Dec 2008 Location: Lansdale
Using Flat Delrin sheets for lower links (like the T1E ones below) works a lot better then using round stock. The 5/16 round stock will flex a little bit more then I personal liked even more so if you bend it. The 5/16 Round will work for uppers though. As stated above the ones below are made by T1e and are relatively cheap. If you are going to make them I suggest doing so with a scroll or band saw as it is a pain to do with a dremel. Trust me I know from experience |
08-07-2011, 09:50 AM | #12 |
Newbie Join Date: Jun 2011 Location: NO
3mm/ 1/8" Acetal POM H (delrin(R) for the chassis sides should work fine. Make sure its the H (High Density) sheets u get. Last edited by GEN; 08-07-2011 at 09:53 AM. Reason: added inches :) |
