03-22-2010, 12:56 PM | #1 |
Rock Stacker Join Date: Oct 2005 Location: Puget Sound
| Making my own TLT wideners, Delrin (Acetal), steel, or 6061?
Hey all, I am wrapping up the fabrication aspect of my senior project, and I have some leftover rod stock in black Acetal, steel, and 6061 T6 (several feet of each, all 2-in dia.), and I was contemplating making a set of wideners for my TLT-based comp crawler, especially since they seem to be kinda hard to source independently. My only real question is this: is there any reason NOT to make a set of 1/2-inch wideners out of the black Acetal? It is typically used in gearing applications as a lighter replacement of steel and aluminum gears. Another idea, should I do all three and use them as weights for front/rear bias? I am already fabricating axle C's, rear straight axle adapters, and steering links out of aluminum and smaller diameter Acetal, and since I seem to have so much stock left over... |
03-22-2010, 03:04 PM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Atlanta
I dont see anything wrong with it. But make sure its a tight fit. If not it will wollow out a lot.
03-24-2010, 05:49 PM | #3 |
Quarry Creeper Join Date: Jan 2007 Location: Ontario, Canada
Steel.
