04-09-2010, 11:27 AM | #1 |
Rock Crawler Join Date: Jul 2009 Location: waterville
| getting holes in your leaf springs?
i am making some leaf springs for a scaler. i took the info from the scaler forum on drilling holes and what to use. well it took 1 hour to make two holes. i used a diamond tip stone. that got burnt up fast. i also used cobalt bits. i know spring steel is hard, but man i have had easier times drilling on hardened steel parts. is there an easier method to doing this that i have not read about? if not ill stick with the long hard method. thanks
04-09-2010, 12:59 PM | #2 |
Quarry Creeper Join Date: Aug 2008 Location: 5280'
i would say use a TON of lube (wd-40,pb blaster,ect) and go nice and easy let the bit do the work.
04-09-2010, 02:03 PM | #3 |
RCC Addict Join Date: Nov 2005 Location: Utah
Just drilled holes in tamiya leafs last night no problem. I've found the titanium nitrade coated bits work the best, they are the brass colored ones.
04-09-2010, 04:42 PM | #4 |
thanks for the replies, i will keep plugging away on them. these are home made leafs out of a mower recoil. i just wasnt sure if there was something i was missing or an easier route. i was soakin em in wd40 while drilling, to reduce the heat on them. i knew they were hard, but holly crap... looking forward to doing the other 7 of them |
04-09-2010, 06:51 PM | #5 | |
Rock Stacker Join Date: Sep 2007 Location: east mich
id use a carbide bit and go slow Quote:
04-09-2010, 08:09 PM | #6 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
jwo i've heard people using a leaf rake blades for scaler springs....they r springy but not very hardened.............bob .... |
04-09-2010, 08:16 PM | #7 |
Rock Stacker Join Date: Dec 2009 Location: Clemson
You could anneal the area that needs drilling. Keep most of the spring cool with a water bucket or something else non-flammable. Heat to cherry red with a torch. Let the heated area air cool so it doesn't re-harden (make sure to keep the "cold" part submersed so it doesn't mess up the spring). *I'm no metallurgist, but this should work... A masonry bit might be another option.. From what I have read, they don't drill as cleanly, but work well for tough metal parts and are fairly cheap. |
04-09-2010, 08:36 PM | #8 |
Quarry Creeper Join Date: Feb 2008 Location: Citrus Heights
get some rap-id-tap instead of wd 40. a new bit and the slowest speed you can. slow speed fast feed.
04-09-2010, 09:51 PM | #9 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
Sounds like your going fast. You need to drill slow
04-09-2010, 10:02 PM | #10 | |||
once again thanks for the responses. it greatly appreciated i hope i can finish these. my hats off to every one that makes their own leafs. | |||
04-09-2010, 10:10 PM | #11 |
Quarry Creeper Join Date: Mar 2009 Location: Torrance, CA
Don't use WD-40. It's NOT a cutting lube. I prefer carbide ball endmills for something like this. You have to peck at it.
04-09-2010, 10:45 PM | #12 |
Pebble Pounder Join Date: Dec 2008 Location: Tomball, Tx
if there is a local tooling supply house, gat a couple of 'screw machine' length drills in the size you need, they are shorter than a standard drill length. the steel they are made from and the point angle grind will be better than anything you can get at the hardware store. The spring material you are using is harder than a preacher at a youth retreat so use slow speed and hard feed. do not try to hold the leaf by hand in the drill press. if the bit grabs, the spring could rip you open.
04-10-2010, 07:20 PM | #13 |
well i was able to get the leafs drilled out. i picked up a 3 more bits today after work. i picked up another cobalt and two titanium bits to try. went down to my old mans welding shop to use the low speed press. in the end i used a piece of c channel to lay behind the leaf. after some trial and error. i had found that putting a hole in the c channel using the size that i was to be using helped out big time.allowed the bit to get maximum bite with out messing up the leaf. the titanium bit ripped right threw it.i though i broke the bit on the first one(only the weight of my hand on the wheel.that only lasted about 2 leafs, then the progress slowed down due to the bit dulling out. this stuff is unbelievably hard.i did 6 of the 8 leafs with one bit. took a few hours to get them done. the nail trick i read about didnt do. burnt the tips right off em, with no heat marks or any thing to the leaf. now that i know how to go about it i wouldn't mind making more at all. thanks to everyone who helped aid my issues. greatly appreciated. |
