04-19-2010, 08:09 PM | #1 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
| cutting 1/4" lexan?
What would be the best way to cut a peice of 1/4" lexan without making it chip or crack? Table saw? Scroll saw? What blade would be best?
04-19-2010, 08:21 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
i use chop saws / table saws to cut almost every thing (just what i have) and iv found a high tooth count and a slow feed speed works well on most things
04-19-2010, 08:24 PM | #3 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
can be careful with a dremel. If it starts to melt a little its no big deal normally the "hangers" will snap right off once they cool. I dont recommend if you are cutting big pieces though. It works good for small little things.
04-19-2010, 08:28 PM | #4 |
04-19-2010, 08:37 PM | #5 |
Ok thanks guys. I have access to a table saw so I'll prolly go that route. The cut will be about 48" long, will I have to worry about going to slow and having it burn/melt?
04-19-2010, 11:09 PM | #6 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
| They sell triple negative rake blades specific for plexiglass work, you can feed it pretty damn fast on the tablesaw with the correct blade, I bought one years ago when I was doing custom nano fish tanks,
04-20-2010, 05:36 AM | #7 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i use my dewalt 12" miter saw with high tooth count saw blade to cut delrin and 1/8" plate along with 1/4" x 1" alum bar stock....i just hit it with bout 1/6" or so deep cut at a time....i made a jig with a block of 2 x 8 to hold down flat stock from the blade ripping it upwards ...........bob .... |
04-20-2010, 09:42 AM | #8 |
Ok, thanks guys.
04-25-2010, 05:06 PM | #9 |
Rock Crawler Join Date: Feb 2005 Location: stafford springs
When I cut it at work for machine guards I usually just use a jigsaw. Only problem is getting a nice straight cut!
04-25-2010, 05:17 PM | #10 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
thickest i usually work with is 3/16. and when cutting lexan we just use wood blades on the jigsaw or on the circular saw for long cuts like what you are doing.
04-26-2010, 09:17 AM | #11 |
Newbie Join Date: Jan 2009 Location: canada
i use my bandsaw and it work awesome
04-26-2010, 09:22 AM | #12 |
I was thinking about just using a jigsaw but I really want it to be straight. Its a windshield on my Teryx and I want to beable to put it back together when winter is here again without any gaps lol.
04-26-2010, 05:20 PM | #13 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
I used to cut 1/2 inch lexan with a jig saw,,,16tpi blade I believe,,,masking tape on the saw plate and on the piece getting cut,,straight edge clamped down to make error free straight line cuts
04-26-2010, 07:49 PM | #14 |
Quarry Creeper Join Date: Sep 2006 Location: Jackson
Rotozips work wonderfully too. All the pieces are thrown out the bottom
04-26-2010, 10:05 PM | #15 |
Quarry Creeper Join Date: Mar 2009 Location: Torrance, CA
Circular saw with a new carbide tipped blade works wonderfully. When making long cuts like what you want, I clamp a 2x4 or similiar to the lexan and use that as a guide.
