04-30-2010, 12:18 PM | #1 |
Rock Crawler Join Date: Oct 2006 Location: Fernley
| Lathe armature belts?
I just picked up a motor lathe, but I need to get a new belt to go around the armature. I am having trouble finding any place that sells them. Any help will be much appreciated. Thanks in advance.
04-30-2010, 01:15 PM | #2 |
Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
I've never seen an actual belt... all the lathes i've used in the past 20 some years use nothing more than a rubber O-ring to connect the pully to arm... ANY hardware store sould have several sizes that will work you want the O-ring tight enough to hold the arm in the V-blocks BUT not so tight it's hard to spin the arm by hand... bout 1/8 thick will be fine. John |
04-30-2010, 01:51 PM | #3 |
Okay. Thanks for the quick response. I'll look into it this weekend.
04-30-2010, 01:58 PM | #4 |
04-30-2010, 02:11 PM | #5 |
Pebble Pounder Join Date: Jan 2010 Location: Glenview
| www.sdp-si.com has a lot of drive components including a lot of weird size belts...
04-30-2010, 03:01 PM | #6 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
Any decent Ace Hardware will have them in all sizes.....you want it to be FIRM, but not too snug.....also, make sure its a thin type not a big thick one. Harbor Freight also sells a big O-Ring kit for like $10.....probably will find one in there. Later EddieO |
