06-04-2010, 01:29 AM | #1 |
Rock Crawler Join Date: Jan 2009 Location: Boise
| vinyl cutter question?
Hey I was looking at getting a vinyl cutter to make custom masks and some stickers. My wife had point out this one called a cricket (sp?) but someone said that it will only cutouts of there pre made desings not ones you make. I am looking for a nice decent priced cutter/sinter and good software program to make designs any suggestions? Thanks Scott
06-04-2010, 03:27 AM | #2 |
Pebble Pounder Join Date: Jan 2010 Location: VIRGINIA BEACH
check ebay thats where i got the two i have one is a uscutter 12" the other is a seiki 34" both came with software
06-04-2010, 09:10 AM | #3 |
Quarry Creeper Join Date: Mar 2010 Location: kelseyville
i got my 54'' from cutter pros cutterpros.com and i paid $1000 with software its awesome
06-04-2010, 09:34 AM | #4 |
Quarry Creeper Join Date: Apr 2008 Location: Racine
I run a 24" PCut from USCutter. You can find them around $250-$300 on Ebay direct from USCutter.
06-04-2010, 09:59 AM | #5 |
RCC Addict Join Date: Jul 2008 Location: Sin City
I have an old Roland CAMM-1 i bought from a guy at work for 300 bucks. Its at least 15 years old and still works great. Hunt around a bit, you can also cut directly from corel with an add-on that saves a ton of money.
06-04-2010, 02:54 PM | #6 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
I have an old US Cutter that I no longer use because I had to upgrade the size. It worked great and I was one of the first ones around RCC to do cut vinyl with it, so I know it works fine. |
06-05-2010, 09:14 AM | #7 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
The Cricut will only do what is pre-programmed in their cartridges. I bought my chick one for xmas for her hobby, was hoping to use it for mine as well but.... What you are needing is a vinyl plotter. Just did a quick google search and it came up with alot of different ones. |
10-24-2010, 12:55 AM | #8 |
Pebble Pounder Join Date: Mar 2005 Location: Kelowna, B.C., Canada
You need to pick up the program "sure cuts a lot" It lets you print any svg file on your cricut from your printer. Paper, vinyl, even thin styrene is no problem... http://www.craftedge.com/index.html vinyl project: These were done by creating a layered pattern that I cut out of styrene using the cricut. And the bed Last edited by outcastrc; 10-24-2010 at 01:06 AM. |
10-24-2010, 01:16 PM | #9 | |
Rock Crawler Join Date: Aug 2010 Location: Salt Lake
X2, I have a cricut as well and use sure cuts a lot. I wished I had bought the larger one as the small one can only do sheets up to 6X12 maximum. | |
10-24-2010, 05:09 PM | #10 |
That is great info. Thanks for posting that up outcastrc... |
10-24-2010, 06:02 PM | #11 |
I am about to buy my first cutter. I am going to go with the GCC Expert 24. Seems to be the best of the budget machines. Comes with software for $350 or so. I was looking at the cricut and some other similar ones and decided that for not that much more I could get a 24" cutter. They also guarantee 3 meter tracking, most of the cheap machines dont track well out that far and that leads to major problems.
10-24-2010, 08:26 PM | #12 |
The cricuts a toy for sure, but when you can buy it for the wife (brownie points) and get some projects out of it for yourself its an amazing device. Added bonus is it buys you freedom from the missus!!! |
10-24-2010, 08:56 PM | #13 |
RCC Paint & Graphics Join Date: Oct 2005 Location: Wauseon, OH.
I use a US Cutters 24" Laserpoint. It's a great machine. Alot of my paint masks are done on it.
11-06-2010, 08:28 PM | #14 |
Newbie Join Date: Dec 2009 Location: sumter
I use surecuts alot for the cricut also. you can get the good vinyl off ebay and it works great. Just takes a little while to get good at creating images.
11-06-2010, 09:24 PM | #15 |
I have a question for you guys. So as I mentioned a couple posts ago I am going to be getting a 24" GCC cutter soon. I am curious how small I can cut. I know that it will be cutter specific but is there a rule of thumb to start out at? I am mainly going to be cutting paint masks so making sure I have everything scaled right from the start would be helpful. Also what are you guys using for your paint mask material? I saw some paint mask specific vinyl online that has a different adhesive that doesnt leave residue after you take it off. Is that necessary or is regular stuff ok to use? Thanks |
11-07-2010, 06:12 PM | #16 |
You probably couldn't cut a logo to scale ie "jeep" or "toyota" but you could cut a grill, or tailights and such. I have used just regular 3m vinyl as a mask before without it leaving residue, but it turns soft and almost gooey so I wouldn't use is as a fine detail mask.
11-07-2010, 08:50 PM | #17 | |
I use Mactac 8900 removable vinyl for my paint masks. No residue and works great. I use yellow but it comes in many colors. Here's where I get mine. http://www.hhsignsupply.com/productc...-543p42763.htm | |
11-08-2010, 06:27 PM | #18 | |
That was the paint mask I was looking at, sounds like I should get some. | |
