06-05-2010, 10:35 PM | #1 |
Quarry Creeper Join Date: Feb 2010 Location: Duluth
| Cutting plastic
Here's a trick That I used to use back in the day, I just remembered it tonight when I had to cut some tail light lenses. Take a bolt or spare soldering tip that threads into your soldering iron, Braze or weld a #2 hobby knife blade to it and screw it into your soldering iron, I used a 25 watt I had laying around, should have used the 60 watt, would have been quicker. Let it heat up then just slice thru what ever plastic you need to cut. Like a hot knife thru butter. |
06-06-2010, 12:53 PM | #2 |
RCC Addict Join Date: Dec 2009 Location: Rock Bouncin' with the Patented Technique
Cool. I always just used an old box cutter, took a torch, and heated the knife up til it was red hot, then cut the plastic. Works probably just like yours, like a hot knife through butter.
06-06-2010, 05:13 PM | #3 |
Rock Crawler Join Date: Jan 2009 Location: Jacksonville FL
damn y didnt i think of that!!!!!!
06-06-2010, 06:48 PM | #4 |
Rock Stacker Join Date: Jan 2010 Location: phoenix
careful with cutting delrin the smoke can kill ya. Otherwise great tip.
06-08-2010, 11:04 AM | #5 |
Pebble Pounder Join Date: Oct 2008 Location: Grand Junction, CO.
I just bought one but only use it for styrene there's lots of scary chemicals in plastic products. http://www3.towerhobbies.com/cgi-bin...?&I=LXSD16&P=7 Last edited by MystRacing; 06-08-2010 at 11:06 AM. |
