07-21-2010, 02:55 PM | #1 |
Pebble Pounder Join Date: May 2010 Location: canada
| brazing with a propane torch??
is it possible to braze with a propane torch??
07-21-2010, 03:45 PM | #2 |
Newbie Join Date: Jun 2010 Location: Champaign
not hot enough I believe for brazing.
07-21-2010, 03:57 PM | #3 |
Rock Stacker Join Date: Jan 2009 Location: kalamazoo
depends on the type of brazing. of you are using silver solder then it should be hot enough but its not hot enough for bronze.
08-03-2010, 03:32 PM | #4 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
08-03-2010, 10:32 PM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: Brown City, Mi.
08-03-2010, 10:50 PM | #6 |
Hateraide Join Date: Dec 2008 Location: Mission BC
08-03-2010, 10:59 PM | #7 |
I know there are posts on how to braze, but I havnt seen what type of rod to use and diameter of rod used to braze. Do you use silver rod? Do people put flux on the rod before its brazed? Sorry, I'm a little slow... |
08-04-2010, 09:33 AM | #8 |
RCC Addict Join Date: Nov 2005 Location: Utah
Yes you can use a propane torch. I've built a few items with a smaller propane torch, it's definitly not as fast, but will work. I haven't used propane for a while, now all i use is my mapp/oxygen set up. And most use safety silv silver solder, but i'm lazy and just use this flux coated brazing rod that my local welding shop gives me.
08-04-2010, 01:02 PM | #9 |
Thanks. |
