![]() | #1 |
RCC Addict Join Date: May 2006 Location: nor-cal
have anyone used the thermal arc 95s tig welder? list your likes and dislikes please1 http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_4466wt_930 Last edited by Wicked_Jester; 07-30-2010 at 06:05 PM. |
![]() | #2 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
i think i would try something larger. if your going to be building a lot for chassis (using it a lot) & doing a lot of starts/stops, watch/look at the duty cycle, the higher the #'s the better. all-so keep in mind, it will go out at some point (something will stop working). & U want a unit that U can find service & parts for ! just my thoughts ![]() the DmG |
![]() | #3 | |
| ![]() Quote:
![]() | #4 | |
Rock Crawler Join Date: Mar 2008 Location: hillbilly illinois
| ![]() Quote:
![]() JMO I would never buy a welder thats less than 230V. A 110 unit may be fine for tiny things but when you want to weld something thats 1/4" thick, 110 won't cut it. Plus the bigger 230 and up units are going to have more tuning options for your arc strengths and widths. You'd be surprised at how much you find to weld once you get one ![]() This is my soon to be home welder http://www.millerwelds.com/products/tig/diversion_165/ These are my (At Work) Babies http://www.millerwelds.com/products/...rowave_250_dx/ http://www.millerwelds.com/products/...atic_350_350p/ and the 350p has this attached http://www.millerwelds.com/products/...poolmatic_30a/ Yea I'm spoiled lol Last edited by addictedtonitro; 07-30-2010 at 07:21 PM. | |
![]() | #5 |
I run a miller mig for my day job and currently use it for my chassis, the tig would be more of a tinker toy ![]() Last edited by Wicked_Jester; 07-30-2010 at 07:22 PM. |
![]() | #6 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
if you're looking for a small one, the older (like 3-4 years) maxstars came in lower amp ratings, and can be found under 1000 used... but don't have pedals, so that pushes them over 1000... I top weld with miller welders daily at work and will also recommend them. Hobart too, cheaper versions of millers that are also sweet!
![]() | #7 |
Pebble Pounder Join Date: Jan 2010 Location: Vancouver
That thermal arc would do you fine if you are welding rc stuff......i doubt you would ever exceed the duty cycle of that machine.It also has a decent reputation.I wouldnt hesitate for a hobby tig machine.
![]() | #8 |
Newbie Join Date: Feb 2006 Location: Ottawa Kansas
For what you are going to do with the thermal arc would be fine. Yes it does not have all the features, duty cycle, etc that a more expensive unit has but you dont need arc shaping and a pulser to weld together a rc chassis. If you have the money then a Miller tig welder is superb but they are not cheap and the cost of the welder is not the only expense. Realistically you can't get into a complete setup with a lower range Miller tig for less than arount 2500 to 3000 dollars new. Now that being said I am also one of the spoiled ones in that at home I have a Miller Syncrowave 300 with a water cooler with all the bells and whistles that I would not trade for anything. The difference is that this welder makes me money on the side welding 1:1 roll cages and fuel cells so I actually use the additional functionality and power. Besides, if you find that you really enjoy tig down the road then you will be able to sell that little thermal arc unit to another beginner for a reasonable price and move up into the more expensive units. P.S. You don't need a three phase welder for aluminum, you just need a AC/DC unit with high frequency. My big miller is a 220-480vac single phase unit, granted it pulls 100amps from the wall at full throttle but it is single phase. Fastball |
![]() | #9 |
Newbie Join Date: Oct 2008 Location: Burbs
| ![]() if you are looking to learn the basics and start to tinker this is absolutely fine. I have owned this for 7 months and love it. It is scratch start so there is no active power control via pedal but it will do the job. I'm building 2 tubers for my son and I and it's worked well for that. I've also welded much thicker stock for other projects. Have not used the stick yet but am on my 3rd bottle. My local welding shop carries this and has been helpful.. I'd buy from a local guy though.. May be few dollars more but you can't replace the help of a good shop.
