09-12-2010, 04:55 PM | #1 |
Rock Crawler Join Date: Sep 2008 Location: Salem,Oregon
| Help fine....
Looking for replacement bolts for ax1o bead locks. I can't find them online I know someone has to carry them but who? Thanks for you time hende.
09-12-2010, 05:09 PM | #2 |
or what size are they?
09-12-2010, 07:52 PM | #3 |
Rock Stacker Join Date: Nov 2008 Location: Streetsboro
M2x10mm socket head cap screws. Depends on haw many you need on where to get them. If you need a few, its better to get them from your local hobby shop. If you need all of them, get them from a hardware supplier like Fastenal or McMaster-Carr. I use McMaster as it literaly 5 minutes from my house and can go pick them up in will call. Heres the link to what you need at McMaster http://www.mcmaster.com/itm/find.ASP...ring=91290A017 |
09-12-2010, 08:51 PM | #4 |
DOOH!!! Join Date: Feb 2007 Location: AZ
Or, support a vendor and go with 2-56 button head screws.. Better gripping in the plastic wheels, plus button head.. http://www.tcscrawlers.com/TCS-Large...s-p-16605.html That will cover 2 full wheels or the outsides of all 4.. |
09-13-2010, 12:39 PM | #5 |
Rock Stacker Join Date: May 2009 Location: Sandpoint
i support the local hardware stores! I had to replace a couple off my old losi MRC, found the right screws at ace after digging through a couple of screw bins!
