09-23-2010, 02:09 PM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: land of 10,000 collapsing bridges (MN)lol
| ~I Need Help!~
im having problems with bending and brazing 3/16 brake line, i need a new bender and was wondering what you guys are using??, also i have saftey silver 45 BUT my map gas torch is lacking is the heat department. im not sure if there is a more concentrated tip or if i should get a hole new torch?? -Randy |
09-23-2010, 04:11 PM | #2 |
I wanna be Dave Join Date: Jul 2008 Location: Southwestern, Ohio
Got a pic of your torch? WWWWWOOOOOOOOOHHHHHHHOOOOOOOOOOOO!!!! Post # 500!!! Sorry! |
09-23-2010, 09:49 PM | #3 |
This Head- on this tank- |
09-23-2010, 10:16 PM | #4 |
Quarry Creeper Join Date: Nov 2006 Location: Longmont
That looks like a propane torch head. Get one made for MAPP, like this one: http://www.bernzomatic.com/PRODUCTS/...3/Default.aspx MAPP wont burn any hotter that propane if it can't get all the oxygen it needs. Also, if you're having trouble with brakeline get some higher quality tubing. I hate working with brakeline, It's a pain in the ass to remove the coating completely enough to get a decent brazed joint. I really like this 1010 steel tubing: http://www1.mscdirect.com/CGI/GSDRVS...00000155301930 A bit more expensive than brakeline but way easier to work with. Last edited by toybuilder; 09-23-2010 at 10:25 PM. |
09-24-2010, 10:19 AM | #5 |
Rock Stacker Join Date: Jun 2010 Location: wnc
thats a propane head fer sure..u need to get a turbo swirl type head for mapp to get it hot enough for hariss 45 silver.. ur best bet is go get one of the small bottle oxy /acetylene kits from lowes.. the heat is more consistent and MUCH easier to work with... |
09-24-2010, 10:34 AM | #6 | ||
09-24-2010, 10:37 AM | #7 |
