Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Best way to bend delrin?
Old 12-13-2010, 11:08 AM   #1
Default Best way to bend delrin?
Hi, new to this forum and to rockcrawling and wondering what way is best for bending delrin to make lower links? Thanks
rollinrooster is offline   Reply With Quote
Old 12-13-2010, 11:32 AM   #2
This should tell ya what you need to know. Just be sure to do it in a well ventiallated area. Delrin puts out some really toxic fumes when burned.
Bend delrin rod questions
HomerJ is offline   Reply With Quote
Old 12-22-2010, 06:11 AM   #3
Drill a hole in a peice of wood (2X4 works fine.) The hole should be "just" larger than the delrin. Insert delrin into hole, slowly bend the delrin down towards the wood. It usually takes 2-3 times holding for 5-10 seconds to stay at a 30 degree bend. Cut to length.
Ideally, you want the depth of the hole to be just deep enough for the short end of your links, so that side wouldn't need cutting again.
Hope this helps.
Shot-N-The Dark is offline   Reply With Quote
Old 12-22-2010, 09:08 AM   #4
DO NOT burn the delrin. Low heat...just enough to make it soft.
JeremyH is offline   Reply With Quote
Old 12-30-2010, 08:25 PM   #5
i use steam
MOVIN-SLOOOOOOW is offline   Reply With Quote
