Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: screw extractor bit ?
Old 02-04-2011, 04:10 PM   #1
Default screw extractor bit ?
Anyone know if a screw exstractor bit would be hard enough to exstract the tip of a Irwin tap. Broke the tip off of a tap inside a bent link I have spent alot of time on.
Aggie01 is offline   Reply With Quote
Old 02-04-2011, 04:16 PM   #2
not likely, Probably both made from the same material High speed steel.
klabeaume is offline   Reply With Quote
Old 02-04-2011, 07:14 PM   #3
Default carbide
i work in a machine shop,, you will need a small carbide drill, but they are kinda pricey,, run it a fast rpm and it will cut it fine,, what size tap?
chase1deer is offline   Reply With Quote
Old 02-05-2011, 01:35 PM   #4
No idea what I'm doing
You could try using a tap extractor. I've had hit and miss results with them though.
C*H*U*D is offline   Reply With Quote
Old 02-05-2011, 02:18 PM   #5
I will assume about a 3mm tap about 1/2" down?? Sorta a sucky situation. Carbide bit would be my first choice, EDM is second, do a new link is third (or maybe 2nd??)
Charlie-III is offline   Reply With Quote
