02-04-2011, 04:10 PM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
| screw extractor bit ?
Anyone know if a screw exstractor bit would be hard enough to exstract the tip of a Irwin tap. Broke the tip off of a tap inside a bent link I have spent alot of time on.
02-04-2011, 04:16 PM | #2 |
RCC Addict Join Date: Nov 2004 Location: union
not likely, Probably both made from the same material High speed steel.
02-04-2011, 07:14 PM | #3 |
Newbie Join Date: Jan 2011 Location: owensboro
| carbide
i work in a machine shop,, you will need a small carbide drill, but they are kinda pricey,, run it a fast rpm and it will cut it fine,, what size tap?
02-05-2011, 01:35 PM | #4 |
You could try using a tap extractor. I've had hit and miss results with them though.
02-05-2011, 02:18 PM | #5 |
I will assume about a 3mm tap about 1/2" down?? Sorta a sucky situation. Carbide bit would be my first choice, EDM is second, do a new link is third (or maybe 2nd??)
