Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Glue metal to delrin...
Old 03-23-2011, 04:46 PM   #1
Default Glue metal to delrin...
What's the best glue or CA to use to glue some stainless screws to some delrin?
2JSC is offline   Reply With Quote
Old 03-23-2011, 05:25 PM   #2
I think you are going to have a tough time with it. Delrin doesn't like being glued. You might try shoe goo I've heard from some that it works. I also ran across this method to etch Delrin in order to prep it for glue or paint:
http://benkrasnow.blogspot.com/2010/...lastic-in.html
I haven't tried it but that guy machines a lot of delrin for projects and I would think that etching the surface chemically would work much better than simply scuffing it with sandpaper. I would suggest a mechanical type of connection if at all possible.
forbid89 is offline   Reply With Quote
Old 03-23-2011, 05:32 PM   #3
Yeah, I'd like to be able to use a nut on the screws, but there isn't any clearance on the backside. Can barely get the screws in as is, and if I clearance the wheels I might ruin the beadlock.
Old 03-23-2011, 05:41 PM   #4
I'd second the shoo goo try to get a little around the screw and it should hold once it sets.
Difuser is offline   Reply With Quote
Old 03-23-2011, 06:05 PM   #5
Might have some of that around here... have to dig through the junk drawer.
