05-21-2011, 02:08 AM | #1 |
Pebble Pounder Join Date: Feb 2011 Location: B.C. , Canada
| maxx shafts made easy
does anyone know where the how to thread is for the maxx shafts made easy mod? for mounting them on axial or similar scale rig
05-21-2011, 02:23 AM | #2 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
i know jason had it somewhere but heres a rundown. drill out the maxx yoke to the size of an axial yoke, cut the ears off the axial yoke. make sure the holes with both yokes line up and press the axial yoke inside the maxx yoke, you can then use a small screw that threads down through both yokes and tightens up on the output shaft. hope that helps |
05-21-2011, 05:44 AM | #3 |
Quarry Creeper Join Date: Apr 2010 Location: Southern Aroostook County
I'll add that its not just maxx shafts that work like this, I used half shafts from my Summit to do pretty much the same mod. I used Traxxas metal joints and the Axial metal joints. I broke the joints down completely and frankenstiened them together to make a completely metal universal joint then cut the ball cup, where the pin goes thru to attatch to the Summit diff, off on both ends. Then drill out the ends of the shafts to accept the universal joint, press in the universal and mark where to drill the hole on the shaft ends ,drill the hole and run an appropriate size screw all the way thru the universal and shaft and cut or grind the excess screw length off. then all you need to do is cut the new shaft to length to fit you truck. If you need any help doing this shoot me a PM, happy to help if you need it
05-23-2011, 12:01 PM | #4 |
Rock Crawler Join Date: Feb 2010 Location: Hayesville
05-24-2011, 04:53 AM | #5 |
Holy cow....I didnt realise the Maxx shaft mod was so complicated....the way Ive been doing my Summit shaft mod only requires cutting the shaft to fit and drilling it out, no cutting off the ears and with my mod you wind up with a all metal joint on both sides of the joint...not saying one is better than the other
05-26-2011, 12:30 PM | #6 | |
