04-27-2006, 11:24 AM | #1 |
Rock Stacker Join Date: Aug 2005 Location: It's hot
| Working with styrene/strength
I'm looking to build a hard top for my current project, and it looks like styrene might be easy to work with, does anyone have any opinions? Also, how strong is it? It's going a on a TLT base rig (for a guess on overall weight), and it will be rolled over quite a bit. I also have the equivalent of a 48x24" sheet of 1/8" lexan already laying around, would that be a better choice durability wise? |
04-27-2006, 02:09 PM | #2 |
Pebble Pounder Join Date: Sep 2004 Location: Manchester UK
Styrene is very easy to work with and versatile. I've just finnished scratch building a shell for my XC. Just make sure all joints are well sealed and if poss reinforced if your going to roll it a lot!!. The max thickness i use is 2mm for the main parts and 1mm and 1.5mm for the rest unless it's fine detail then i'll use 0.5mm. http://www.tcphotos.com/getuserimage...06153644_2.jpg http://www.tcphotos.com/getuserimage...06153644_3.jpg http://www.tcphotos.com/getuserimage...06153644_4.jpg If you get stuck just PM me or mail me as information is FREE!! Steve |
04-27-2006, 09:38 PM | #3 |
How much 'give' does styrene have? I know that with lexan, if I "touch" something pretty good, it's going to come apart at the seams. Is the styrene stuff very flexible?
04-28-2006, 02:52 AM | #4 |
It depends on what thickness styrene you use,Even the thinnest can be made strong by useing ribs to reinforce it. With the truck above i can put full pressure on it and push it into the ground with NO flex at all. If the shell/body your going to build is fairly square the reinforce all corners with rightangled styrene. |
04-28-2006, 01:38 PM | #5 |
Thanks for all the input, it looks like I'll be using styrene since it seems pretty easy to work with. I can envision the lexan splitting apart once it hits something fairly hard. Using a gloss paint, I can't picture a difference aesthetically to inside painted lexan, and the exterior painted styrene. |
04-28-2006, 02:09 PM | #6 |
Check your gloss paint on a spare piece first as some will react with styrene. good luck with the build . Steve |
