08-23-2011, 12:53 AM | #21 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
I like the 6" looking but the diameter limit kills me Since a bandsaw isn't cheap I want to be able to rip out 2.5" diameter Delrin blanks for rims easy, is it any good or save my $ for a bandsaw and go from there. On a side note their 1x30 belt sander, at least what I got, is NICE! Good deal |
08-23-2011, 03:11 AM | #22 |
Newbie Join Date: Jul 2011 Location: CC
| mine
im buyin em
08-23-2011, 07:26 AM | #23 | |
RCC Addict Join Date: Feb 2006 Location: Medford, Oregon
If you are talking about the 6" chop saw, you would need an actual blade to safely cut delrin with. I haven't seen any high tooth count(plastic cutting) blades in 6" I have an older Ryobi 8" Miter saw I found a 150 tooth blade that fits. Works great on delrin, without melting it. Or you could save for a bandsaw. You can get pretty cheap tabletop versions. Especially since you don't have a need for large capacity. I've seen new Chinese made 9" bandsaws for less than $100. I also have the 1x30 sander from HF. it does work amazingly well, considering I've had and been using mine for over 5 years without fail(knocking on wood). i found that belts from Grainger last easily 5 times longer for it. | |
08-23-2011, 09:37 AM | #24 |
Not as cheap, or as small as the chop saw, but http://www.harborfreight.com/power-t...saw-96980.html |
08-23-2011, 09:44 AM | #25 |
I used the 6" chop saw the other day to cut some 4mm think Grade 8 washers for knuckle weight add on's. I was surprised this tool handled the metal pretty easy. Good $40 purchase! Thanks for the heads up on it. Link... http://www.harborfreight.com/6-inch-...saw-41453.html |
08-23-2011, 11:18 AM | #26 | |
I got mine as a gift from my mom and minus the HF belts being "eh" its amazing! Done some dual station steel vises im working on with it and so on, handy little thing As for belts im getting some in the mail shortly, I tore up one when a part I had got sucked into the sander, I removed the table | |
08-23-2011, 11:26 AM | #27 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
Picked up the 6" saw at Harbor Freight yesterday for $27.99 with a coupon. It's made my life a lot easier already.
08-24-2011, 07:46 AM | #28 | |
http://www.amazon.com/gp/product/B00...Z1709HM87ZVH94 I've seen one of these in person at a local tool shop. Pretty darn nicely put together little saw. Never seen this one in person, but I've never got anythign bad from Micromark yet. http://www.micromark.com/9-Inch-Band-Saw,9960.html | |
08-25-2011, 12:21 AM | #29 | |
08-25-2011, 07:50 AM | #30 |
For cutting Delrin I prefer a table saw and 10" chop saw. I don't use a high tooth count blade either, and it works great. The reason I prefer the table saw is because not only are the cuts straight, but parallel which is important when trying to hold Delrin in a machinist vise since the sides are smooth. Calvin, are you cutting round stock or square? When I have a lot of parts to make from Delrin, I have the plastics shop cut my pieces for me. Their cut charge is pretty minimal compared to the time it takes me to cut myself. |
08-25-2011, 07:51 AM | #31 |
Rock Crawler Join Date: Mar 2010 Location: NRV
anyone used one of these: http://www.amazon.com/Proxxon-37006-...4280010&sr=1-4 I've always wanted a Proxxon to rip stuff down to precision scale but their table saw is almost $400, Micro mark is similar. My concern with the harbor freight one, or any cheap one for that matter, is the precision that it can cut. This has some bad reviews as far as precision but wonder if anyone has used it. |
08-26-2011, 05:22 PM | #32 |
Juan, mostly round. For me driving to somewhere is a bit farther than i'd like I'd love to have a saw to do more than 'just' Delrin sheets since I may cut some aluminum and steel for tool holders and the such |
08-29-2011, 05:18 AM | #33 |
I have used that Chop Saw now for over 3yrs making Deling Links.. I couldn't tell you how many I have cut. I'm even still using the same blade that came with it.. Never saw the Table saw... But it would come in handy for a few things.. I'm going to give it a shot.
09-21-2011, 08:04 PM | #34 |
For those wanting to cut steel, i found these guys...i'm assuming the saw has a 3/8" arbor http://www.ebay.com/itm/25pc-Metal-S...#ht_1400wt_932 There's other thickness as well, down to 1/32" |
