07-23-2011, 11:42 PM | #1 |
Rock Stacker Join Date: Jul 2011 Location: Denton Co
| brass buggy
I want to build a rail dune buggy using the front and rear of a super champ . Will brass tube work to make the cage? I want it to be driveable. Thank you for any info you can give me.
07-24-2011, 04:46 PM | #2 |
Pebble Pounder Join Date: Feb 2005 Location: Chandler, AZ
yes, it will work. Ive built a tuber out of 1/8" brass tube. Harris safety silv works great although brass isn't magnetic, so you'll need a third hand to help assemble it. The brass tube isn't as stiff as steel so you'll need to design carefully and maybe add reinforcement later.
07-24-2011, 06:36 PM | #3 |
Just build it out of steel. Brass is not a good material for this purpose.
07-24-2011, 11:54 PM | #4 |
Rock Stacker Join Date: Jan 2009 Location: kalamazoo
brass will work just fine, i know because i have done it several times.
07-25-2011, 11:47 AM | #5 |
| I have seen them done before but they don't hold to real abuse. It could be done yes but for it to hold up to real bashing it would require so much more triangulation, bracing and hours than a steel version. That is why all of us use steel. Way back when a lot of us tried using brass, in the end we just gave up because of the durability.
07-25-2011, 05:47 PM | #6 |
RCC Addict Join Date: Jun 2008 Location: In the woods
yes definately use steel.you can pick up 3/16" brakeline for around $7 for 6' stick at local parts store.it is very durable and cheap.part # are advanced and autozone is PA-372(well i know it is at advanced auto) and i think it is the same at autozone also.
07-26-2011, 09:17 AM | #7 |
thanks
07-27-2011, 11:02 AM | #8 |
07-27-2011, 11:23 AM | #9 |
RCC Addict Join Date: Oct 2007 Location: gervais
| Lol ya he got alot, I guess they're trying to be more sneaky
07-27-2011, 11:32 AM | #10 |
