08-05-2011, 03:02 AM | #1 |
| Harbor Freight Cheap Heat Gun!
While going into Harbor Freight to pick up some clamps and shrink wrap I saw a decent heat gun on sale....had to get it! Turns out Harbor Freight and Tools has a 1500 watt dual temp heat gun for $12.99!! 6' power cord with 2 setting 1112 deg High and 572 deg Low. Brand is Drill Master check it out! |
08-05-2011, 11:07 AM | #2 |
Yeah I have bought a similar heat gun from them too,'mine is made by Chicago electric though. Its also 1500 watts and 2 settings. I bought it after seeing prices at sears and other stores (stickershock) so I went to HF instead
08-05-2011, 11:14 AM | #3 |
Rock Crawler Join Date: Dec 2007 Location: Maple Grove, MN
I got one from them as well. It's cheap, and I do not expect for it to last long. But, with what I used it for... I like it!
08-05-2011, 01:24 PM | #4 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
Been using this gun for the past 2 years and it has been used quite a bit over that time....it is holding up well.
08-05-2011, 01:29 PM | #5 |
I've got the Chicago one as well. Can't say anything bad about it. Used it to bend delrin and even warped a stock scx10 bevel gear trying to warm up a seized bearing for removal
08-07-2011, 09:59 PM | #6 |
Rock Stacker Join Date: Mar 2007 Location: Bethpage,TN
Harbor freight does have good prices but you have to check things out as some tools they sell are so inferior they don't do the intended job. I bought a pipe thread there and it broke without making good threads on the first pipe.
08-08-2011, 05:25 AM | #7 |
Rock Stacker Join Date: May 2010 Location: Tacoma
Funny you mention that I just bougt one about a week ago its amazing can easily set things on fire if your not careful.
08-08-2011, 08:06 AM | #8 |
Rock Crawler Join Date: Mar 2009 Location: Alvin,Texas
ive had the same heat gun for 2 years with no problems. and i use it alot. |
