09-12-2011, 06:40 PM | #1 |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
| bending formula?
Was searching around and didn't find much. So, is there a formula for making bends? i.e., I know what length my straight link is. But would now like to make a bent version of said link and still keep the same length of the straight one. Everytime I make bent links I over shoot the overall length by 1/4 - 1/2 inch. Then cut as needed. I'd like to make one cut, then bend and be done with it. I checked the machinist handbook but it gave these ridiculous equations. Just wondering if there is an easier way. Thanks in advance.
09-12-2011, 06:56 PM | #2 |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
the correct formula is called k factor, but unless your using properly controlled bending equipment your results will vary. http://en.wikipedia.org/wiki/K-facto...al%29#K-factor Last edited by tom@vp; 09-13-2011 at 09:19 AM. |
09-12-2011, 06:57 PM | #3 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
Formula=practice |
09-12-2011, 07:09 PM | #4 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
usually i make a drawing of the piece i want to bend (chassis rail or something) then i take a piece of string and form it to the drawing then stretch string out measure onto your tube or rod and thats the right length... or at least close to it.
09-12-2011, 08:33 PM | #5 |
Search for bending 101, its a good write up over on pirate 4x4. It will get you to the point that you can bend just about anything in one axis. The basics are as follows:
Its easy, when you start doing complex bends it gets a little more complicated. |
09-12-2011, 08:56 PM | #6 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| there you go....man, I'm pretty good with math...but that formula was brutal...
09-12-2011, 08:59 PM | #7 |
I didn't see SMR's until after I posted mine....but that's a good idea too.. might even get some tubing and give it a try |
09-12-2011, 09:07 PM | #8 |
I believe there are some reference charts in the 'machinerys Handbook' for bending allowance, different types of materials 'grow' on outside bends. There are many variables involved with calculating a bending allowance. The cheap and easy way is to use graph paper and draw out what you want to bend, then use the lines in the graph to make a straight line measurement. |
09-12-2011, 10:09 PM | #9 | |
I have used this method to successfully bend different hoops to match width very closely. I almost feel like a 1:1 would be easier because you could compensate for 1/8" of variation very easily. With 1:10 scale that would be 1/80" hard to get that precise. Nothing will help more than bending and then bending some more. Learn your bender, no matter what bender you are using bought or made at home you need to learn how it will bend. | |
09-13-2011, 05:44 AM | #10 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
trail and error with the small benders we use....since i got back into R/C's with a crawler "the tigress" and now scalers, i have been bending brake line for 3 years now....as said starting in the middle and work your way to the ends has been a good formula....single bend bent links are the easiest to make compaired to making frames....i find it easier to have a longer length then needed and cut both ends, less wasted time starting with a new piece of tube and less waste....you can't add to what you have cause you started with less then you thought, you can always shorten what you started with .........bob .... |
09-13-2011, 05:06 PM | #11 |
thanks for the tips guys. just what i was looking for. much appreciated. |
09-16-2011, 11:22 PM | #12 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
to get the basics pick up a "Uglys" hand book...its a electricians bible...has lots of formulas and how to do stuff.* *wiring is not a hobby, hire a professional before you burn your house down. |
