05-31-2006, 07:10 AM | #1 |
Newbie Join Date: Apr 2006 Location: australia
| anyone managed to bend delrin rods for clearance yet
anyone managed to bend delrin rods for clearance yet and if so how is it done thanks in advance and does it weaken it ive got 5/16 delrin that i want to bend into shape to use for links
05-31-2006, 07:50 AM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I've never tried it, but Delrin is hard to bend so it stays in that shape. You might be able to heat the area you want to bend first.
05-31-2006, 08:08 AM | #3 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
05-31-2006, 08:13 AM | #4 |
Pebble Pounder Join Date: Jan 2006 Location: Evansville
| Just a thought
I have never worked with any delrin before but this might work. I did this with 3/4" pvc conduit, I needed a pc the had a zig-zag in it. So I drew the pattern I needed on a pc. of 3/4" plywood, them I hammered nails in just enough so that they would stay, I put them on the outside edges of the pattern I drew. Finishing nails work best because they have almost no head. I then heat the pc. of conduit with a propane torch until it was warm enough to bend, Then I put it between the nails on the plywood and let it cool.(actually I poured cold water on it to cool it off because I didn't want to wait. Anyway it turned out great. I think this would work for you and with the pattern you would be able to bend your links exactly the same everytime. Hope this helps. Brian |
05-31-2006, 03:03 PM | #5 |
tjamks for the fast replys guys verry helpful as usual
