12-14-2011, 02:44 PM | #1 |
Newbie Join Date: Dec 2011 Location: Chatsworth
| i need a template to make 4 link plate for axial ax10
i want to make my own 4 link plates for my axial ax10 and i have the experience and tools but i need a pattern to trace because i dont already a 4 link front and rear plate to trace and dont know anyone that has one i can copy and nor do i have the exprience to creat my own because i dont know where the holes for the shocks should be placed to get the maximum performance out of the ax10. i want one for the front and rear. if anyone has a template or knows where i can find a template please post it i dont find it worth it to pay what one cost when if i can find a template i can do it myself for nothing and in probably a hours time. |
12-14-2011, 03:45 PM | #2 |
| Re: i need a template to make 4 link plate for axial ax10 |
12-14-2011, 04:13 PM | #3 |
Thanks a lot I'll build those here pretty soon unless anyone knows of a better design. What are some other parts that would be easy to make and save me some Money if their is any other parts and are the new rover tires any good and would the scrub I have herd of some of the large tires like them scrubbing when you turn hard right |
12-14-2011, 06:23 PM | #4 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
easy parts to make are chassis plates, skid plates, links stuff like that.
07-03-2012, 09:26 AM | #5 | |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: i need a template to make 4 link plate for axial ax10 Quote: nice stuff man!!! THANKS!!!! I like the manta.. may try a hand at it... slooooow build with my son.. as funds come in ... noob question... is the "Manta" a already known rc car? i googled it and didnt see it.. wanted to get ideas of shock links, 4 link, etc... just something to look at.. thanks! | |
07-03-2012, 09:44 PM | #6 | |
I might have a Manta build thread in the ax10 section...don't really remember. There still might be pics in the Tmaxx section of my MegaManta but its been a long time since I've looked there either. FYI: it is not a comp legal chassis. Dimensionally it is too small. | |
07-17-2012, 11:57 PM | #7 |
Newbie Join Date: May 2009 Location: NOR*CAL
I have the original ax10 kit. When I 4 linked it I used the extra servo plate and drilled two holes in it and counter sunk the holes and threw it out back. Batta Bing! 4link on the cheap
07-19-2012, 11:12 PM | #8 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
I personally have never made the Manta either but I have made quite a few chassis with a drill press, hack saw and some patience. Duuude has a good thread for those of us without CNC access, like me One idea would be to take the drill pattern from it and translate that to a larger, comp legal chassis and your set or just run it as a "bare bones" chassis with a shell on top. Skies the limit That being said take your time and you never know what you may come up with |
01-20-2013, 10:16 PM | #9 |
Quarry Creeper Join Date: Jan 2008 Location: Hellsberry
| Re: i need a template to make 4 link plate for axial ax10 What did you use for links? Did you use the stock llnk? If so, did it change pinion angle?
01-21-2013, 06:20 AM | #10 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
CHUD, Manta, and I have templates posted old ones...very simple and work. You want "better" you won't find templates. It's not hard to make at all. |
01-21-2013, 09:27 PM | #11 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
when i needed to make link plates for my axial axle....i used masking tape on the 1/8" alum and just pressed the top tubes on there axle housing to imprint the tape where those holes need to be drilled and designed a plate around those holes....
01-21-2013, 10:48 PM | #12 | |
02-01-2013, 08:44 PM | #13 |
Quarry Creeper Join Date: Jul 2006 Location: Huntspatch
The masking tape idea is a great tip. Forgot all about that one. Perfect timing also, solved a problem for me. Thanks
Tags |
4 link plate, axial ax10 scorpion, create, template |
