07-06-2006, 11:23 PM | #1 |
| MM to SAE?
Does anyone know where I can find a Calculator online to convert mm to standards?
07-06-2006, 11:34 PM | #2 |
Never Mind I found one. http://convert.french-property.co.uk/index.htm |
07-06-2006, 11:54 PM | #3 |
Rock Stacker Join Date: Mar 2006 Location: Australia
if you type convert then the amounts and types you want to convert into google it will do it for you. Ie: convert 3 mm to inches and it gives you the answer |
07-06-2006, 11:58 PM | #4 |
What I'm trying to do is figure out what 2-56 x 1/4....Is that real close to 3mm x 8mm?
07-07-2006, 02:35 AM | #5 |
Newbie Join Date: Nov 2005 Location: Hayden
Run2 A 3mm x 8mm screw is much larger than a 2-56 x 1/4" screw. The 3mm x 8mm screw is .118" diameter by .315" in length. The 2-56 x 1/4" screw is .086" in diameter by .250" in length. The SAE decimal for 1mm is .03937". Hope this helps. |
07-08-2006, 05:20 AM | #6 |
Pebble Pounder Join Date: Apr 2005 Location: In my shop
Here is one of the best converters you can download. Converts anything. http://joshmadison.net/software/convert/ Bret |
08-06-2006, 07:19 PM | #7 |
Rock Stacker Join Date: Jul 2006 Location: Lincoln
Here is a nice page of several different conversion tools. I have it in my favorites. http://www.towerhobbies.com/help/convcalcs.html |
08-07-2006, 12:06 PM | #8 |
Pebble Pounder Join Date: Jan 2005 Location: st. louis
11-19-2006, 01:38 AM | #9 |
Man I have been using this thing alot lately. http://convert.french-property.co.uk/index.htm |
11-19-2006, 08:33 AM | #10 | |
RCC Addict Join Date: Dec 2004 Location: Central NY
