07-07-2012, 12:39 AM | #1 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| tube and rod jig
I had a need to cross drill steel rod and tube so I welded some 14g sheet steel together as a base and then cut a piece of 16g steel angle and welded it onto the base and then cut off the static end of a 2" C-clamp and welded it on the base to clamp the rods or tubes into the angle guide...works well..thought Id share a simple solution...will work for notching tubing too. |
07-07-2012, 08:35 PM | #2 |
Pebble Pounder Join Date: Jan 2011 Location: Peace and Quiet
| Re: tube and rod jig
Thats pretty cool for a cheap bench vice!! |
07-08-2012, 09:39 PM | #3 |
Thanks..it works very well...and like you said..cheap.
07-21-2012, 07:44 PM | #4 |
Quarry Creeper Join Date: Jan 2009 Location: B-E-A-utiful Vancouver Island
great idea .... think i might have to steal it for notchin tube
tube and rod jig - Similar Threads | ||||
Tube Chassis Cage Jig? | CrewCabScaler | Tools, and Procedures | 7 | 12-29-2011 04:00 PM |
Berg tube jig for drill press.. | Chris_The_Battery_Man | Tools, and Procedures | 10 | 10-21-2011 09:31 AM |
solid rod vs. tube chassis | kurt | General Crawlers | 1 | 09-26-2010 09:50 AM |
aluminum rod or tube | wakeboardfusion | General Crawlers | 5 | 02-20-2009 10:44 PM |
What do you use to bend you tube/rod? | Going Up! | Tools, and Procedures | 2 | 10-17-2007 08:28 PM |
