11-10-2010, 05:10 PM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: Vancouver,Canada
| Best grease for gears in axle
Hi looking to find what will be best grease in gears in the axles? Is VP(blue) grease or tamya ceramic grease good? Just need good grease for the gears need to get my rig ready for my first comp. Thanks |
11-10-2010, 05:19 PM | #2 |
in all mine i just use a automotive wheel bearing grease except my losi comp crawler uses lucas oil red and tacky all with good results
11-10-2010, 07:41 PM | #3 |
Newbie Join Date: Feb 2008 Location: metropolis
I usually use a real light coat of regular ol wheel bearing grease as well. I really don't see it making much difference between one type or another, as long as there is something on there. I hate getting something that someone has packed full, and its filthy trying to clean it all out. Something turning some serious rpm's like a savage or something I could see it maybe being a little more important.
11-10-2010, 07:46 PM | #4 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
| X2, whatevers cheap, if I know i'll be in water, the housing will be packed full of it, I took my CC01 rear axle apart and it was full of water.
11-10-2010, 09:16 PM | #5 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
I use lucas red and tacky or mobil 1 synthetic whichever is closer to me when I need it...
11-10-2010, 09:21 PM | #6 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
Pro Boat marine grease....
11-10-2010, 09:30 PM | #7 |
I recently started using Losi Great Grease in my trucks (MOA and LCC) and am extremely happy with the results. It quieted the gears significantly in my bully...
11-11-2010, 05:51 PM | #8 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
hello all. Doesn't petroleum products cause plastic to soften? The reason i'm asking is because i'm going to clean and repack diff and tranny gears for the first time
11-11-2010, 06:04 PM | #9 |
Crisco does wonders.
11-11-2010, 07:39 PM | #10 |
Quarry Creeper Join Date: Dec 2009 Location: St. Augustine
I use lucas red in my mud bogger with good results.
11-12-2010, 06:54 PM | #11 |
I'm an avid supporter of Lucas Red and Tacky #2. I used to pressure wash heavy equipment and the only grease you couldn't wash off was the Lucas. You could spread it into a thinner layer, but not remove it. I run it in all of my fullsize rigs without issue so it should be good enough for an RC crawler. I also pack my trans/axles full as part of a water damage prevention package. |
11-12-2010, 08:02 PM | #12 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
11-12-2010, 10:08 PM | #13 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
11-13-2010, 10:57 AM | #14 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
Rocksmith gear jelly is good stuff. Team3six can hook you up with some. Personally I stick with what I get from work, "chixsan" or "arctic" grease. We use it in our commercial LIQUID PROPANE pumps. Tacky and smooth.
11-13-2010, 01:42 PM | #15 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
Gorilla Snawt |
11-13-2010, 07:32 PM | #16 |
Rock Crawler Join Date: Jun 2009 Location: summertown
i use the red and tacky in all my transmissions but i have found that the lucas X-TRA Heavy Duty #2 "green" grease works better in my worms |
11-14-2010, 11:25 AM | #17 |
Quarry Creeper Join Date: Apr 2009 Location: Israel
Rocksmith engeneering gear jelly is all I use.
11-18-2010, 10:02 PM | #18 |
Thanks all i got Mobile 1
11-19-2010, 02:41 PM | #19 |
I use Castrol extreme pressure bearing grease. It's a dark red color, sticky as glue and it stinks to high hell!
11-21-2010, 11:19 AM | #20 |
Quarry Creeper Join Date: Nov 2007 Location: Cincinnati
marine grease. a must for us scuba divers. |
