| | #61 |
| Pebble Pounder Join Date: Nov 2005 Location: NHFF World HQ, TN
| relatively.... crawler gears don't see that high of torque or speed compared to many industrial applications. Being that everything in a crawler could be treated as an open gear application (since the axles and gearboxes don't really seal) I'd use a grease specific for open gear applications like JAX Gear Guard Synthetic. I've got some to run in my crawler *I work for JAX INC btw. Lubrication Engineer |
| Sponsored Links | |
| | #62 | |
| RCC Addict Join Date: May 2010 Location: Los Altos, California
| | #63 |
| Rock Stacker Join Date: Sep 2010 Location: SE
| bearing grease |
| | #64 |
| Rock Crawler ![]() Join Date: Oct 2010 Location: Ontario
| Work for a Chrysler dealer and have been using bearing grease in all the diffs and on the gears and joints and is works mint. On the electronics I use di-electric grease i have tried others but for free the mopar stuff is the best for me. |
| | #65 |
| Rock Crawler Join Date: Jun 2010 Location: Australia NSW
| so castrol marine grease would be ok? what about that black graphite type grease? (both automotive types) |
| | #66 |
| Quarry Creeper ![]() Join Date: Jan 2011 Location: Augusta
| I go with marine grease if I know I'm going into some deep water and mud. I like how it helps repel the H2o and dirt from the axles. |
| | #67 |
| Rock Stacker Join Date: Mar 2010 Location: Canada
| rocksmith gear jelly, team3six will hook you up, stuff works good |
| | #68 |
| Newbie Join Date: Jul 2010 Location: Shelby Twp.
| I use amsoil synthetic spray grease. No complaints so far. |
| | #69 |
| Rock Crawler Join Date: May 2009 Location: Medford, Oregon
| Mobil 1 synthetic here as well. |
| | #70 |
| Rock Stacker Join Date: Sep 2011 Location: longview, WA
| I would say marine grease if you go in water? I have boats and i have been using the proboat marine grease for everything! it works in my 1/8 brushess revo, my 1/16 slash, i use it in my trani to keep the sand out of my dune bugy stampede! Think about it...its engineered to keep water out of your stuffing tube wile not bing slung out! My boat shafts turn up to 50,000rmp so i would hope that it would hold on to a crawler axle. eather way... use what you got and somthing is always better than nothing!!! Just my two pennys |
| | #71 |
| Rock Crawler ![]() Join Date: Dec 2006 Location: Oak Ridge, TN
| Automotive bearing grease. I do like jelly on my toast in the morning though. |
| | #72 |
| ΜΟΛΩΝ ΛΑΒΕ ![]() Join Date: Dec 2005 Location: 3%
| Vasoline. |
| | #73 |
| Square is for.. squares! ![]() Join Date: Jun 2011 Location: San Diego
| I used some 80w gear oil I had lying around. I am miles away from well educated regarding gear oil, but at the temperatures, speeds, and pressures I can't imagine it matters whether you lube with crisco or gear jelly. I also run a full synthetic for 15k miles per change in a hot rodded engine. Maybe one of the engineers can chime in since my entire education about oil and it's effectiveness is related to a closed system with journal bearings that produce high pressure. Last edited by opek; 10-01-2011 at 07:53 PM. |
| | #74 |
| Quarry Creeper Join Date: Feb 2011 Location: s. terra firma
| I use Mobil 1 synthetic grease in my axles and transmission. Ive taken them apart , it works great. Its easy to get autozone has it along with any major auto parts stores. Ya its a little bit more money but you dont have to maintain it all that well. |
| | #75 |
| Pebble Pounder Join Date: May 2009 Location: Northern Virginia, USA
| | #76 |
| Quarry Creeper Join Date: Oct 2011 Location: Detroit
| | #77 |
| | #78 |
| | #79 |
| Newbie Join Date: Oct 2011 Location: Edmonton, AB
| Does anyone know if a semi-synthetic lithium complex grease is okay to use with plastics? The reason I ask is because big tubes of it come with actuator rebuild kits at work and there is always lots left over after a rebuild. Its red and extremely sticky. Thanks |
| | #80 |
| RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| couldnt find marine grease (asked dad about it since he builds aluminum boats for a living) but couldnt get a straight answer out of him so i bought some red n tacky #2... so i'll try that and see how it works. |
| Thread Tools | |
| Display Modes | |
