09-21-2012, 03:15 PM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| flat bottom countersunk holes?
i have a bumper that i want to sink some cap head screws in to get them flush. you can see the bumpers in my build thread (http://www.rccrawler.com/forum/1-9-s...sters-6x6.html). any suggestions on what type of bit i could use? basically i want to drill a cylinder out. i tested a typical bit on a piece of scrap aluminum and it did make the hole ok but the angled bottom isn't working for me. input welcome.
09-21-2012, 03:30 PM | #2 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
| Re: flat bottom countersunk holes?
Very cool build! Try a forstner bit...it probably won't work on too many holes or on wood again but i bet it'll work for you. Pre-drill with a small bit to line up the starter point in the bit. |
09-21-2012, 03:36 PM | #3 |
Rock Crawler Join Date: Oct 2009 Location: RC Blackhole
try double drilling with a flat bottom drill. grind the point off a drill and some angled relief in the middle so it only uses the outer 1/3 of the flutes. sorry i don't have a pic but done this hundreds of times when an endmill wasn't an option.
09-21-2012, 03:38 PM | #4 |
thanks for the input. i think those are just what i'm looking for. i see a few places that carry them. most look like 1/4" is the smallest size. that might be about right. |
09-21-2012, 03:41 PM | #5 | |
| Re: flat bottom countersunk holes? Quote:
this does make me regret throwing out my broken bits! | |
09-21-2012, 05:34 PM | #6 |
Newbie Join Date: Jan 2009 Location: Everett
What you should use is a counter bore tool. With a pilot on the tool, you could use a handdrill but a drillpress would give you depth control. Try McMaster-Carr Phil |
09-21-2012, 06:01 PM | #7 | |
i've ground drills into boring bars and groove tools for special situations and always have a few junk ones laying around for this reason, so i don't throw all of them out | |
09-21-2012, 06:03 PM | #8 |
Counterbore is the way to go...With the pilot lining it up is foolproof and they come in sizes specifically for cap head screws.
09-21-2012, 07:10 PM | #10 |
thanks for all the advice. one of the reasons i support this site! i was about to put in an order to mcmaster anyway so i think i'll throw one of these bits in the shopping cart. |
09-23-2012, 10:25 AM | #11 |
Rock Stacker Join Date: Feb 2012 Location: Longview
| Re: flat bottom countersunk holes? This is the most correct answer. Piloted counterbores are designed for this. Other stuff might work, but a piloted counterbore is very proven |
09-23-2012, 12:19 PM | #12 | ||
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
I use these at work a lot, right tool for the right job. | ||
flat bottom countersunk holes? - Similar Threads | ||||
Pls help: motor plate holes won't fit with tekin motor holes | painter4x4 | Axial Wraith | 11 | 02-04-2012 08:06 AM |
flat spotted proline flat irons? | brianw | Newbie General | 4 | 02-12-2010 12:50 PM |
bottom links | Bam Bam | Tamiya Txt-1 and Juggernaut | 19 | 10-05-2005 12:30 PM |
