Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: can a mini torch do it
Old 09-23-2006, 12:57 AM   #1
Exclamation can a mini torch do it
hey wats up everyone,
i was wonderin if those little hand held butain torches would be powerfull enough to braze cooper or brake line?? thx for all who replies.
alaskakid89 is offline   Reply With Quote
Old 09-23-2006, 02:31 AM   #2
I'm a stupid C U N T!
slobin3d's Avatar
i use a mapp torch and it still takes a while to heatup and melt ve used half a bottle to do one tuber
slobin3d is offline   Reply With Quote
Old 09-23-2006, 06:59 PM   #3
wat material did u use?? cooper or steel brake line
Old 09-23-2006, 10:03 PM   #4
slobin3d's Avatar
I was using 5/16 brakeline.
Old 09-23-2006, 10:52 PM   #5
k thanks
Old 09-23-2006, 11:32 PM   #6
I've used about half a bottle of MAPP on a exo cage. I dont have a problem with it heating slowly or not enough.
xjman is offline   Reply With Quote
Old 09-24-2006, 07:39 PM   #7
I joined the Band!
I use brake line. Mostly because its light and strong at the same time, Also I used a little butane torch to get it hot and some steel solder
Bronco is offline   Reply With Quote
Old 09-25-2006, 09:56 PM   #8
do u have ta use flux with brakeline brazing??
Old 09-25-2006, 10:05 PM   #9
Do you have to use flux when brazing with brakeline?
A brazing flux will help to a certain degree, but I have found that it isn't really needed. Nice, clean joints without flux will meld just fine.
Robb is offline   Reply With Quote
Old 09-25-2006, 10:18 PM   #10
thx
