10-03-2006, 08:40 AM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
| Need help with material?
I just finished making a mold for some skids and need to know a good plastic or resine to use for the skid. I was going to use the same stuff for it but I'm thinking I need something a little better. Any help? |
10-03-2006, 06:14 PM | #2 |
I know someone knows something. I was thinking of Carbon fiber but never used the stuff before. I would rather have something that can be used in a mold instead of molding around something. If that makes sence. ? |
10-04-2006, 04:54 AM | #3 |
Pebble Pounder Join Date: Jan 2005 Location: st. louis
no sure, but I know laying up carbon fiber is not cheep. The cloth cost a pile, then you have to build up the layers like fiber glass. once laid up you have to put it in a vacuum bag and cook it in an autoclave. you could try to do the same with regular fiberglass, might hold up to the beating. |
10-04-2006, 08:51 AM | #4 |
Thanks I guess it's time to call my engineer friend. |
10-04-2006, 09:00 AM | #5 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
Ive decided to use positive and negative molds and use heated up sheets of fibered ABS, You jsut heat it up and press into the forms. I will be making the first pressings tomorrow or Friday I heat em up in a toaster oven,,,,,,,(hi tech tools!) Last edited by rockwerks; 10-04-2006 at 09:05 AM. | |
10-04-2006, 09:13 AM | #6 |
Any links to the fibered ABS?
10-04-2006, 09:17 AM | #7 | |
