| | #1 |
| I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
| I just finished making a mold for some skids and need to know a good plastic or resine to use for the skid. I was going to use the same stuff for it but I'm thinking I need something a little better. Any help? |
| Sponsored Links | |
| | #2 |
| I know someone knows something. I was thinking of Carbon fiber but never used the stuff before. I would rather have something that can be used in a mold instead of molding around something. If that makes sence. ? |
| | #3 |
| Pebble Pounder Join Date: Jan 2005 Location: st. louis
| no sure, but I know laying up carbon fiber is not cheep. The cloth cost a pile, then you have to build up the layers like fiber glass. once laid up you have to put it in a vacuum bag and cook it in an autoclave. you could try to do the same with regular fiberglass, might hold up to the beating. |
| | #4 |
| Thanks I guess it's time to call my engineer friend. |
| | #5 | |
| I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
Ive decided to use positive and negative molds and use heated up sheets of fibered ABS, You jsut heat it up and press into the forms. I will be making the first pressings tomorrow or Friday I heat em up in a toaster oven,,,,,,,(hi tech tools!) Last edited by rockwerks; 10-04-2006 at 10:05 AM. | |
| | #6 |
| Any links to the fibered ABS? |
| | #7 | |
| Thread Tools | |
| Display Modes | |
