| | #1 |
| Rock Crawler Join Date: Jul 2006 Location: Ridge Spring SC
| how do you prevent crimping of the tube when bending a corner. tring to make cab |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jan 2006 Location: In the basement
| Use a bigger diamater bend. Are you using a tube bender? |
| | #3 | |
| I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
What are you bending the metal with? Last edited by Cole82; 10-09-2006 at 08:32 PM. | |
| | #4 | |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
Diameter/radius.........tomato/tomAto. | |
| | #5 |
| Thanks Robb I fixed it for you |
| | #6 |
| ... Join Date: Sep 2005 Location: USA
| Your best bet is to use a Bender. You can also get the bend started by bending it around something like a softball bat. Then bend it by hand. Thats what I do if I need one with a bigger radius bend. Manily I just use a vise for all of it. |
| | #7 | |
| Dirt Addict ![]() Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Jay | |
| | #8 |
| im using a vise but the edges on the vise ar like squared off and the crimp the bend even with the slightest force. iv learned to work with it bend it a little at a time but its a little rough but not all that bad |
| | #9 |
| OK, either get a brakeline tuber bender (best) or try clamping a piece of steel tube (~1" diameter) in your vice and bend the tube around that. Jay |
| | #10 |
| Scale Jedi ![]() Join Date: Jan 2006 Location: The Hive
| just figureded this one out the other day. after making your measurements for the location of the bend, bust out the dremel or hack saw and cut HALF-way thru the tube . on 3/16" tube i can get 90' of bend by slicing the tube 4 times about 1/16' apart and start bending till the cuts touch. if it still isn't enough, cut out somemore. then when you have the desired angle, braze or weld in place, then fill the cut section with braze or weld . seems to be working well for those tight radius's and will also let you adjust your angles to help square every thing up! i never use a bender, waste of money if you ask me. just get you a peice of plywood or mdf at least 3/4" thick, 2 or 3 decent sized nuts & bolts, put it together and youv'e got a jig. then you can bend 2 at a time so things match up, works great! |
| | #11 | |
Plus it's cheap http://www.northerntool.com/webapp/w...70_33396_33396 | |
| | #12 |
| Just use 3/16 solid rod and a Vise to do all your bends. That can make about anything with out problems and easy. |
| | #13 |
| I'd say getting everything perfectly striaght. |
| | #14 |
| Godlike ![]() Join Date: Jul 2005 Location: Central Coast
| I'm using 3/16 brakeline tubing and a brakeline bender. I'm using a Jeep Rubicon body for size reference (standard style tuber using hood, fenders and doors) I'm not able to make the bends tight enough around the headlights. I've got no vice, so its a little tougher to secure things down. Any ideas? |
| | #15 | |
| I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
I used my brake line bender a bunch when I first started now I rarely use it at all. I found I can do more with my hands than with the bender. It is good to start off with as it gives you and idea of what the brake line will do. | |
| | #16 |
| A softball bat works well for bends. You can use the handle for those tighter bends and the sweet spot for those longer bends. I know it sounds stupid but works extremly well. |
| | #17 |
| I used my finger and my forarm, those worked really well for most bends. for things that needed a little tighter bend I used my manhood. Now I have a tube bender and I'm hoping to get off my lazy *** and use it. |
| | #18 |
| alright COLE82, a bender is faster and easier, and possibly more accurate. but benders won't let you do anything this tight. when i saw LOONEYBIN was buliding a cab i figured he meant really tight turns like these: to keep things square i try to start with a ladder frame, and put it together on the concrete floor. you still may end up cutting some or most of it off later to accomidate your design, but then you can use those for triangulation pieces. then just make each piece two at a time with the jig i suggested above so there exactly the same & this should help you keep things square...hope this helps! |
| | #19 |
| Quarry Creeper Join Date: Feb 2004
| | #20 | |
Basically I want to do what you did to the Jeep on the left, except I want to connect a bar from the stinger tube to just inside of the headlight tube (where the bar is straight). How exactly do you bend the tube with another over it? Do you just use the larger dia tube for leverage? I might just build the rest of the buggy and have someone bend me a headlight setup. By the way, your two rigs kickass, nice job man. | |
| Thread Tools | |
| Display Modes | |
