Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: Tools for narrowing tires.
Old 10-10-2006, 05:44 PM   #1
Default Tools for narrowing tires.
I did a search, but didn't come up with anything. What does everyone use to narrow tires? Just a regular pair scizzorz? I need to un-widen some 2.2 claw dawgs for a cherokee prerunner, but dont know where to start. Thanks in advance.
mrwonderful is offline   Reply With Quote
Old 10-10-2006, 06:08 PM   #2
regular scissors wont work. Use the curved lexan scissors they work like a charm
Gula is offline   Reply With Quote
Old 10-10-2006, 10:29 PM   #3
Location: a place of settlement, activity, or residence.
A dremel with a cut-off wheel mounted in a fixture to hold it perpendicular to your work surface. Set the height of the cutter and rotate the tire along it with the tool running.
thaclodking is offline   Reply With Quote
Old 10-11-2006, 05:44 AM   #4
Just do it the hardcore way. Use your teeth.
Old 10-12-2006, 12:01 AM   #5
Nail Clippers, a butter knife and a map gas torch...
Just messing.
I've used heavy duty scissors and they work very well, just need to have a very steady hand.
If you can trace a line where you want to cut, it'll make it a lot easier.
tecnica2001 is offline   Reply With Quote
Old 10-12-2006, 02:17 AM   #6
insanerc is offline   Reply With Quote
Old 10-12-2006, 06:17 PM   #7
I just narrowed a set of Mashers with some HD scissors and glued them together with Lost Tire glue. It's my first time using that glue and I like a lot better tghan the IC2000 I've used in the past.
rckjeep is offline   Reply With Quote
