11-19-2013, 12:12 PM | #1 |
Newbie Join Date: Nov 2013 Location: Edmonton
| planning to make a frame/chassis
Hey, I'm looking to make a sandrail frame and chassis for a 1/8 scale nitro. It will be 2wd. I'm looking for some tips on building frames by brazing and what materials/ tools would be good to use. Thanks
11-19-2013, 02:37 PM | #2 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Re: planning to make a frame/chassis
Look through my build thread and you'll see what I've brazed up with 3/16" steel break line and a oxy/mapp gas torch. It's not difficult at all, you only have to figure out the gas settings, which is slightly open the mapp, light the gas then open oxy enough to get a good flame.
11-19-2013, 03:00 PM | #3 |
Quarry Creeper Join Date: Jan 2013 Location: Benicia/Vallejo
Clean, clean, clean! The prep work is the most important. Completely remove all the coating/plating/paint/rust/oil/dirt/slag off of all the material before starting the first cut or bend. Make sure all the joints are tight with no gaps. Apply a liberal amount of flux paste to the whole area where the heat from the torch is applied. heat the joint until the flux melts smooth like glass, then flow the solder Use high content silver solder. I like 45% keep a wet rag, spray bottle full of water to quench the hot flux. this helps remove the flux easily For the tubing, there's several options ranging from 3/16 & 1/4" brakline to 1/8"-1/4" cold rolled steel to DOM (drawn over mandrel) steel tubing The Smith "little torch" is awesome for rc chassis brazing and they thread onto standard oxy/acetylene torch regulators Use the search function! there are tons of threads that go over this same subject Last edited by 1tonscout; 11-19-2013 at 05:46 PM. |
11-19-2013, 05:34 PM | #4 |
Nice info from 1tonscout, use it and you'll be successful.
11-20-2013, 12:08 PM | #5 |
I kinda make a rollcage with a soldering iron and steel brake line. I found some 3/16 solid steel that I thought would make a good frame as well. Thoughts on steel rod ? And I gotta say, you know your stuff scout. Thanks for the tips |
11-20-2013, 06:02 PM | #6 |
Steel rod is heavier and needs more heat to braze while tubing is lighter and easier to braze. The solid rod will also add weight on the top side of the chassis,.which would raise your cog(center of gravity) the lower the cog is the more stable the rig will ne.
planning to make a frame/chassis - Similar Threads | ||||
Planning on building my own chassis need help | andrew_deaton | 1.9 Scale Rigs | 3 | 05-22-2012 03:24 PM |
How to make a clod buster tube frame | heminutt | Newbie General | 11 | 11-19-2008 12:45 PM |
planning to make a clod crawlers | aicecoldone | Tamiya Clod Buster | 3 | 06-26-2005 12:07 PM |
Planning to make a crawler, a few Q's | offroad | Traxxas Crawlers | 5 | 02-11-2005 06:01 PM |
