| | #1 |
| Pebble Pounder Join Date: Apr 2004 Location: westminster
| Ok I'm ready to build my first tuber. i want to try and make the best as I can. my question is when i fish mouth my tube can i sand down the outer edge of the tube for a thicker brass/bond? because I want to be able to sand down the joint's and make it look as one. i don't want to be sanding the joint so it will be weak. |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Aug 2006 Location: High Point
| yeah if you brazed a bit extra to sand down, throw some pics when you get it finished |
| | #3 | |
| AKA TOKEN ![]() Join Date: Dec 2005 Location: "Used" Mexico
| | #4 |
| I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
| What he said. ^^ |
| | #5 |
| Pebble Pounder Join Date: Aug 2006 Location: just west of "joisey"
| Depending how tight your joint is, it should flow nicely.. |
| | #6 |
| cool thanx guy's I just asked because awile back i bought a cantilever syle truck tuber and it looked real bad when I got it so i did'nt do anything with it. oh and as soon as i get started i will take pix of it all step by step type stuff |
| | #7 |
| another question anyone use aluminum tube and make a tuber??? pro's and con's of using alum?? |
| | #8 |
| Pebble Pounder Join Date: Nov 2005 Location: N. Arkansas
| aluminum would work I would think but alot of care would have to go into the design so the frame is SUPER rigid. If it has any flex it will crack. |
| | #9 |
| cool thanx guy's |
| Thread Tools | |
| Display Modes | |
